Question about SanDisk Sansa e200 MP3 Player
My sansa e200
I got an mp3player and i pluged it into the printer usb instead of the computer now it doesnt turn on unlesss i plug it into the printer and then its just a blue screen please!!!!!! help me this is my mom's and i have told her yet what should i do?
You should just plug it into the computer and use real player.
Posted on Jan 13, 2007
I plug my sansa E200 in my computer and nothing pops up and its not im My Computer i just want to know what i have to do to put music on it???????????
Hello:
As i see the Computer Won't Recongnize it.
Well most likely its gonna be a Problem with the USB connection:
Try to inspect one of these:
  • Drivers Not Installed/Corrupted.
  • problem with USB Cord.
  • Problem with USB porte in PC
  • Probel with USB Plug in the Mp3 Player.
Good luck
Nov 04, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
Aug 05, 2009 | SanDisk Sansa e200 MP3 Player
My Sansa e260 Mp3 player isn't recognised by Windows and will not show up as connected.
e200 is the generic name for the entire e-series including the e250, e260, and e280. The only difference between the models is the amount of internal memory. The e200 driver is used for all models in the series, and the e200 manual likewise covers the series.
Oct 23, 2008 | SanDisk Sansa e200 MP3 Player
Problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
  1. Turn on the e200 v2
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the e200 drive(s) to show up
  6. Follow instructions below and drag files to the e200 drive
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Did you try to plug the mp3 player in to the usb while the CD was in?
Jun 02, 2008 | SanDisk Sansa e200 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200(1GB) MP3player
you plug it in to your computer with the supplied USB cable
hope this helps
Apr 10, 2008 | SanDisk Sansa c200 MP3 Player
Cant find mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Sansa Recovery Tool
PDF how to use recovery tool
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
Explanation:
The e200 can operated under two different modes, MTP (Media Transfer Protocol) mode and MSC (Mass Storage Class) mode.
To see the MicroSD card as a Removable Disk, the e200 must be in MSC mode. The following screen shots show how the "My Computer" screen will look when the device is plugged in under each mode.
MTP Mode
MSC Mode
Solution:
To change the mode from MTP to MSC go to the Main Menu of the e200.
If you're e200 is plugged into your computer, please unplug it first.
1) Scroll to the "Settings" > "USB Mode" > "MSC Mode" and push the select button.
2) Connect the e200 to the computer using the USB cable provided.
3) Go to "My Computer" and there will now be two Removable Disk drives similar to the MSC Mode image on top.
Answer ID: 356 Created: 03/23/2006 Updated: 03/24/2006
For Products: MP3 -> All Sansa e200 Series , Mobile Memory Cards -> All microSD and microSDHC
Category(s): Audio Player , Computer Only-> Windows XP
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Can't connect!
Has to be Windows XP for either USB Mode but im not sure whether u can connect it to other computers under different versions of Windows or not and I know Apple computers dont work at all with the Sansa E200 series. Also connect ur Sansa to the rear USB inputs instead of the front inputs. Something that has to do with power distribution if none of these call their tech support they were very helpful with my issue.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
