Question about Dynex 19 in. LCD Flat-Panel HDTV
HDMI video stutters, blanks, returns...sometimes every few second
Take a look at the video that I shot of the problem, because it's a lot easier to see what I mean than to try to describe it:
www.joeganci.com/TV_Problem.wmv
Let me know if you have any ideas. Thanks!
  • joeganci Nov 28, 2008
    Sorry, I should have mentioned that this is FIOSTV from Verizon FIOS. Does that help? Thanks for trying thus far.
    Thank you. You've given me some ideas to try.
  • 905 Answers
Hdmi has a bad habit of messing up tv's
but is this satellite that you are using for the hdmi? or cable?
digital signals can do this when inforrmation is messed up comming in to the reciever , also if the box is having internal problems this will happen
can you check the signal level for that station with the info button?
Posted on Nov 28, 2008
  • jason Nov 28, 2008
    that would be probably why
    because it being digital tv the digital signals can do that , and if they( verizon) are having the technical difficulty with the digital signals then you will see it like that , when it is real bad then the picture will freeze and the sound will cut out
    because verizon fios is all digital now you will experience that happening to other channels as well
    also the hdmi input will cause more problems than just having the s-video or yellow rca jack for video connection , most of the tv's that have been using hdmi , have had problems and need repair to the input circuit of the hdmi
    does this happen on other channels? if so then it could be the service provider or box
    if it only happens on one channel then it is the station signal stream
    have you tried another type of line from the box ? like the s-video or yellow rca jack for video into the tv? does it still do it? then it may be the box if it still does it , but again could be the service also
    hope this info is worth a fixya as all other ratings hurt our scoring
    and if you still need assistance I'll be glad to assist you
    electech
How do I fix my ps4's audio stutters. I have it hooked up directly to my SANSUI HDMI tv via HDMI cord.
Could it be the internet connection sometimes is not fast enough? or someone else is downloading from the net the same time, or just streaming music or video over the net. All kind of reasons why the sound could stutters.
Sep 11, 2014 | Video Game Consoles & Games
TV Freezes up and once in a while goes blank then turns back on after about 10 second when I am watching something
Try to use a different cable. If your using hdmi, try component instead. Sometimes there's a data conflict with hdmi
Jun 13, 2014 | Sharp " AQUOS Quattron / 60"" Class / LED...
Acer AL1923 monitor attached to Macbook Pro with HDMI. Works, but goes blank for 20 - 30 seconds or so every now and then. Can't find a Pac driver for it. Does one exist?
this is a problem sometimes with hdmi. it also happens with dvd players. try to do a cold reboot of your laptop and see if that helps. also before turning of your laptop do the same with your monitor. turn it off, wait a few seconds, then turn it on. after that turn your laptop on.
Jun 21, 2010 | Computers & Internet
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Hdmi doesn't work
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Don't hold it to long or it will go on stand-by.
Also try reversing the ends of the HDMI
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Dynex 19 in. LCD Flat-Panel HDTV Logo
142 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
