my television is 1yr old,i was watching a film last night and the tv just turned it self off,after changing the fuse and trying different wall sockits the tv still does not work.it has worked fine for the past year and had know warning signs that anything was wrong,kind regards d hughes
Comments:
Jan 16, 2007
- thankyou very much for your help toshiba are now going to repair the television.
-   My 32" wide screen telly ive had for 2 years & last nite it just fizzed & switched itself off, now when i push the on button on the front all i get is a clicking sound as if its trying to switch itself on & the red light keeps flashing, i've tried changing plugs & fuses but no joy, plz help as its not an old telly.-   reallywicked
Toshiba 32AF41 When we turn it on it has a click sound as if it turning on and no picture comes. The...
(More)
Toshiba 32AF41 When we turn it on it has a click sound as if it turning on and no picture comes. The light next to the power button flashes red.
I have 2 Toshibas. The remote function for my 27AF41 no longer works. I have eliminated the remote...
(More)
I have 2 Toshibas. The remote function for my 27AF41 no longer works. I have eliminated the remote control being defective, since it works on another Toshiba. I have even replaced the TV's remote control receiver.
If I unplug the unit and wait about 20 seconds and then plug it in again, the tv turns inself back...
(More)
If I unplug the unit and wait about 20 seconds and then plug it in again, the tv turns inself back on....this can happen 3 or 4 times in the first few minutes of operation daily. When this first happened, the color also went haywire and I cannot adjust the color at all any longer -- the picture is green tone top-heavy and the color adjustment does not work. This has been going on for about 6 months. Can it be fixed????
I have a Sony SXRD KDS-50A2000 television. I will get a horizonal red line across the entire screen...
(More)
I have a Sony SXRD KDS-50A2000 television. I will get a horizonal red line across the entire screen from time to time. I also will have the TV not power up because the bulb over heats even though the fans running.
the tv was turned off now it will not turn back on. When you plug the tv in, it sounds as if it's...
(More)
the tv was turned off now it will not turn back on. When you plug the tv in, it sounds as if it's going to power on, then the red light starts flashing. We were told the tv is in a security shut down mode. We have checked all the fuses, and left it unplugged for more then a week. Still it won''t fully turn on. The light just blinks it sounds as if it will power on, then the light just blinks.
