The washer will only fill on the top temp setting. It was working, then husband set on Hot to wash something. When I went to do the next load I set it back to cold/cold, the washer won't fill. It doesn't even hum like it is trying to get water. It will fill on hot and hot only.
My washer has started to have a problem with the cold water not coming on for the rinse cycle. I will hear the machine making a electric humming noise, but when I switch the knobs to different settings to try to make the cold water come on, it doesn't work. This problem started about a month ago; after it sat for a day or so, the problem went away. But the problem is back. I am using the hot water setting right now to try and rinse a blanket. It doesn't matter where on the dial I set the cycle -- wash, rinse, extra rinse -- the cold water will not come on. I know the faucet works. That is not the problem. I bought my machine new in 2004 from Sears. It is listed as "Heavy Duty/Oversize Capacity Plus/Quiet Plus/4 Speed Select/Automatic Temperature Control/25 Cycles". It is model # (P)HAV4657EWW.
