Question about Sony NW-E407 (1 GB) MP3 Player
Won't recognise music installed and buttons don't work
The display and search/menu buttons won't work when pressed, but the volume and play button work (kinda). I says that there is a format error and it won't recognise the music thats been installed, although Sonicstage recognises it fine. It still works as a flash drive without problems. I tried to do a format through the in built menu but because the buttons don't produce a response I'm stuck. When set to hold, it flashes the word HOLD on and off for no reason (no buttons are being pressed). It does say theres a format error. Any help would be appreciated. Thanks
  • tarajohnson Jan 07, 2008
    i tried usb lead says music is in the folder but when usb lead took out the mp3 player is not got no music in any folder
SOURCE: i need help adding music to my sony walkman
it's the 4GB NWZ-A816PNK Walkman version?
connect usb to your computer
wait for the connect sound
open my computer
look for removeable drive
right click on it and explore
go to music folder
open your library
drag w/e songs u want into the music folder
dc, turn on. browse and play. hope this helps.
Posted on Feb 24, 2008
SOURCE: "snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Posted on Mar 26, 2008
nadroj12246
  • 66 Answers
SOURCE: my mp3 players volume button
hi,have you tried diff headphones? or maby the jack is broken??
hope this helps :-)
Posted on Sep 03, 2008
  • 82 Answers
SOURCE: Sony SonicStage and NW-A1000
U need to loigin as admin and uninstall and reinstall the softw in a diff location and relocate the database
Posted on Jul 13, 2009
webmaster21
  • 803 Answers
SOURCE: I plug NWA3000 into the computer to change music,
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds or Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. then us: If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 31, 2009
Testimonial: "I did all that it works... thanks.. :O)"
Volume does not adjust, when pressing the volume button up or down, jabra bluetooth tells me the status of the battery, but won't adjust the volume up or down
I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Feb 23, 2013 | Jabra Extreme2 Bluetooth Headset
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Zte score x500 muve music won't launch?
Try Hard Resetting the device and check if it works.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display press the Menu key at the bottom of the screen;3) Choose "Wipe data/factory reset" through volume key4) Press "Camera" key to confirm the above item5) Choose "YES...delete all user data"6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Dec 10, 2012 | ZTE Cell Phones
Volume will not change on my trio v2 plus
In the playing music mode, press the center button one time and then hit either the button to the right to raise the volume or the button to the left to lower the volume.If you hold down the center button it gives you other options.
May 09, 2012 | Mach Speed Audio Players & Recorders
Dolby rca tv v chip code i need it
Hello
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
Aug 19, 2011 | Televison & Video
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
    Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
  1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Sony NW-E407 (1 GB) MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
