Question about GE JVM1190 Microwave Oven
Micro wave will not turn on.
When I try to use bake ,convection or broil I get an F2 error on the screen
  • GE Master
  • 9,098 Answers
F2 means you have a bad temperature sensor (also called a thermal sensor or thermistor).
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
How much time does the convection feature shave off of the traditional time?
no time
it is a convection over with a element to heat the food rather than micro waves
Dec 01, 2015 | Microwave Ovens
My microwave turns on but no heat and its not spinning
No heat --is a failed front electronic panel or
micro wave gun
No turn table-- is a broken belt under the cabinet
Aug 13, 2014 | Cuisinart CMW-200 Convection/Microwave...
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Too HOT to touch
how old is this, check the intake and extract vents for obstructions
Aug 30, 2008 | GE JVM1790 1000 Watts Convection /...
Lid for 13 x 9 baking dish
Use aluminium foil to cover the baker. But only in convection case, not for micro waves cooking !
Jul 13, 2017 | GE Advantium 120 Convection/Microwave Oven
Setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 29, 2007 | Samsung MT1066SS Convection/Microwave Oven
GE JVM1190 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
