Question about Kodak Easyshare M753 Digital Camera
M753 kodak camera does not come on.
The camera worked fine when I used it last December 2007. The battery needed to be charged. I couldn't get the battery to charge on the docking station or plugged in to the computer with the usb cable, so I purchased a new battery and a wall charger. The old battery and the new battery both charged. I inserted into the m753 camera thinking the charged batteries would now turn on the camera. No such luck. Camera won't turn on. I read several people are having the same problem. Is there a recall on this model camera? The camera is less than a year old, but I do not have my purchase receipt anymore. I would have sent it in for the warranty dept to check it out. Can you tell me what are my options?
  • ad-donjon Dec 05, 2008
    Bought camera December 2007 and suddenly will not turn on at all! The battery is all charged- I have used it within the past month. I no longer have the receipt. What do I need to do?
  • Anonymous Dec 07, 2008
    same problem here. any solutions yet?
    Problem Solver:
  • 3 Answers
Go to the nearest electronic place that sells cameras they will tell you wats wrong
Posted on Dec 07, 2008
How long will the batters last on kodak m753 iv had the camera for 7 years
The battery life is quoted as 250-350 pictures in auto mode. This would be for a new battery and camera and it is likely that the number of recharging cycles on a 7 year life will have led to some deterioration in the battery life. The two links below take you to pages from which you can download the Users guide and getting started guide in a pdf format.
Good luck
Aug 25, 2014 | Kodak Easyshare M753 Digital Camera
My M753 Kodak Digital Camera won't charge the battery or turn on. Is there a resolution to fix it??
If the battery is the problem then yes it can be fixed, but you could have a more serious underlining issue, you said the battery was not charging, is the charging light coming on ? or is it completely dead? If the light is working then the battery needs to be checked, if there is no charge light, this would indicate a systems control board problem which controls vital areas of the camera.
Feb 13, 2011 | Kodak Easyshare M753 Digital Camera
How long to charge battery
Your Kodak Easyshare M753 Digital Camera should get fully charged in less than 3.5 hours.
The maximum you can charge or keep the batter for charging is 3.5 hours particularly for your model.
If this is not the case and your battery does not get full charged or takes more longer time then there are chances your battery is worn out and may need a replacement.
However, if you are using re-chargeable batteries then you can also charge the Kodak battery by connecting it to PC/Laptop
For further reference, please check this link as well - Link
Fixya Technical Team
Nov 02, 2010 | Kodak Easyshare M753 Digital Camera
Just won't power up! Tryed the battery from my sam
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Oct 27, 2009 | Kodak Easyshare M753 Digital Camera
Kodak m753 lens error 101, 1, 0, 0
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
Aug 06, 2009 | Kodak Easyshare M753 Digital Camera
My Kodak EasyShare M753 wont turn on at all, but when i tried charging it, it still wouldnt turn on. I have tried lots of different charging methods, like my USD port that came with the camera and my...
This problem is frequently due to corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Jun 28, 2009 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 is not charging.
You LI-Ion battery is bad and not holding a charge. Buy a new one.
Apr 08, 2009 | Kodak Easyshare M753 Digital Camera
Camra dead. M 753
Have you tried cleaning the battery contacts inside the camera? This simple fix (use a fine wire brush, steel wool, or fine sandpaper) clears about 90% of the non-charging and quick shutoff problems with these cameras.
Jan 19, 2009 | Kodak Easyshare M753 Digital Camera
Kodak m753
to remove the purple tint on your LCD screen, all you need to do is:
1. Turn the camera off.
2. Take out the batteries and wait about 10 seconds.
3. Replace the batteries with new or freshly charged batteries.
4. Remove the memory card from the camera.
5. Turn the camera back on.
If the issue is not resolved, send cam for repair. Kodak cameras have 1 year warranty
Aug 06, 2008 | Kodak Easyshare M753 Digital Camera
Won't turn on
Make sure you have the correct cable, not all will work for the m753
May 15, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
153 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
