Question about GE PSW26SGRSS Side by Side Refrigerator
GE PSC23SGRDSS Icemaker not working
I have about a 13 month old GE Profile PSC23SGRDSS that all of sudden, ice maker is not working/not making any ice. I'm still able to get water out of the dispenser, but no ice. Where to begin?
  • 237 Answers
Take the ice maker out and pull the square cover off of it. If you have the type with a plastic "gear" (about the size of a half dollar) on it check to see if the tabs that hold it in place are not broken (it's common). The gear can get cocked or even fall off and that will cause the IM to stop working. If it's the type with a circuit board in it check it for loose connectors, etc. Both types have a thermostat in them to sense the temp of the freezer (must be about 15-17F for IM to work). It's rare that the t-stats go out but it can happen. The "motor module" is a high failure item (about $60 bucks and easy to replace). Let us know what you find.
Posted on Jan 14, 2007
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
    i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
    Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
    Home from vacation--no ice.
    Check the fill area of the ice maker for an ice blockage.
    - make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
    - check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
    - Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
    If your icemaker is the common one there here is a way to test it:
    (I noted GE Profile but not an exact model number)
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
    Last question... does water in door work?
    Thanks for using FixYa.
    Kelly
    Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
    Ice maker in our GE profile refrigerator is not working
    Ice maker Diagnostic Test:
    - Remove the ice bucket
    -Turn the ice maker off, wait 15 seconds than turn it back on
    -Press the ice paddle three times, this will begin diagnostic test.
    -PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
    -In 3 minutes you should see the rack inside turn 360 degrees
    -AND the ice maker bowl should fill with water
    -IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
    Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    I have a PSS26 ge profile fridge and it quit making ice
    The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
    Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    My water dispenser suddenly has stopped working.
    Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
    Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
    New ge fridge ice maker stopped producing ice
    check filter or waler valve may be is the icemaker call service
    Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice maker doesn't make enough ice
    Try turning the thermostat all the way down if it works you can back it down.
    Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
    Ice maker not working
    have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
    Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
    GE PSW26SGRSS Side by Side Refrigerator Logo
    339 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    richie46
