Question about HP LaserJet 1100 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Bought used printer with used cartridge installed. Print was lite but readable. It had a one inch background smudge band running down page, text in that area was darker.After cleaning and printing about 30+ pages, issue finally went away. Finally got to the point text was unreadable. Replaced cartridge with new HP, first it printed a page with smudge in a different location. Then today it printed two pages perfect, then starts printing only text in about 2" column with a smudge in background, the rest of page has faint trace of text only. I rolled cartridge again, same problem. I ran a clean test two times. No change. I put old back in and printed a few pages. Now smudge is worse than before.
  • catchacopen Nov 28, 2008
    You're suggesting the whole fuser ***'y be replaced, not just the sleeve right?
    Problem Solver:
  • 5 Answers
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Posted on Nov 28, 2008
Replace cartridge on hplaserjet2300dn
Hello!
Thank you for your inquiry.
HP LaserJet 2300dn The HP LaserJet 2300dn printer is the same as the HP LaserJet 2300n printer, except that the printer comes with a built-in duplexer (for automatically printing on both sides of paper).
Here is a link to the user guide that will help help you with a lot of common problems including managing the print cartridge area on beginning on page 68. http://www.avss.ucsb.edu/download/hp2300man.pdf
If this is a new toner cartridge the installation instructions will be included inside the packaging including instructions on eco-sensitive means of disposal of old cartridge.
If this is your first time installation you will find it's very simple.
  • Turn the printer off.
  • Open the top cover.
  • If new - remove any orange tabs labeled remove 1st. If this is a replacement cartridge grab the old toner cartridge by the finger hold indentation and pull up.
CAUTION
To prevent damage to the print cartridge, do not expose it to light for
more than a few minutes.
Be careful not to touch the transfer roller (the black, rubber roller located
underneath the print cartridge). Skin oils on the roller can cause
print-quality problems.
  • Install the new print cartridge. It should slide easily down the guide slots on either side.
  • Close the top cover.
Note:
If the print cartridge is difficult to reinstall, make sure that the registration
plate has been flipped back down into position and that you have
pushed the print cartridge firmly in place.
  • Power the printer back on.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Thanks for using FixYa,
TF
May 16, 2011 | HP LaserJet 2300dn Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
When copying or printing, there is a whitish strip down the center where the rollers are. Print in this area is very faint. Thank you for any advice.
Remove the toner cartridge and while keeping relatively level, shake it from side to side. Re-install and try a test print. If the light band has gone away then problem solved. It does mean that your toner crtridge is probably starting to get low on toner. 90% of the time, print quality issues on HP lasers are toner cartridge related.
Good Luck and Thank You for using Fixya.
Aug 05, 2010 | HP LaserJet 3050 All-In-One Printer
My hp laserjet 1100 prints but when it does there is a vertical area on the page that doesn't print. What is the problem?
The toner maybe low and not putting enough toner powder onto the drum.
Remove the toner cartridge and give it a shake, make sure the cartridge is shaken in a level position. Replace the cartridge and do a test print.
If it is still a problem then the photo drum in the toner cartridge is probably faulty, then you need a new toner cartridge/drum.
Sep 01, 2009 | HP Office Equipment & Supplies
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
445 people viewed this question
Ben Johnson
