I have a Magnavox MPD1810A portable DVD player and it does not work. Sometimes when a DVD is inserted it reads: Loading but that is all it does. I cannot watch anything on it but the laser is in tact and the DVD spins inside (sometimes).
  • Anonymous May 14, 2009
    when loading a dvd, it says no disc
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
simplemitch
  • 752 Answers
SOURCE: insignia portable dvd player: disc not spinning
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
simplemitch
  • 752 Answers
SOURCE: INSIGNIA IS-PD040922
  • 579 Answers
SOURCE: Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Posted on Jan 02, 2008
Dvd not reading portable magnavox
Check and replace the optical pick up unit. It might be faulty. Clean it by inserting a lens cleaner disc into the device, and play it at least 2 times. If this do not help you, the fault is said above.
May 29, 2012 | Magnavox MPD885 85 in Portable DVD Player...
My Tru Tech portable dvd player is only a year old and just quit working. When you insert a dvd, it comes up with it's typical, ''loading''. Instead of going to the movie it just satays on the loading...
It's a wonder that DVDs (or even CDs) are read at all; the positioning mechanisms reading them have to deal with millionths of an inch precision and anything can upset the alignment of them.
You might try cleaning the path of the laser with a simple 'cleaning disk' you can buy at electronics outlets. They are not expensive (<$10 US) and can sometimes restore operation by removing dust from the light path. If this doesn't help, I'm afraid you have just another Chinese dumpster item since the repair costs will likely exceed the replacement cost.
Jan 24, 2010 | TruTech PVS12701 Portable DVD Player
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
Cannot read disc
Had the same type of problem; I called Magnavox on this one. These DVD players aren't "guaranteed" to be able to read discs that were "burned"/homemade. They're only "guaranteed" to play commerically produced DVDs. If you're trying to play something that you made it probably isn't going to work.
Jul 31, 2008 | Philips Magnavox MPD845
Magnavox portable dvd player
i've had two magnavoxes, one that i just got about 2 months ago and they're both doing that. I got a lens cleaner CD from walmart, it's like $15, but that didn't completely fix the problem. It helped for a little while, but then the player completely broke and won't even load the cleaner. I'm not going to buy magnavox things anymore.
Jun 02, 2008 | Philips Magnavox MPD845
Magnavox dv200mw8 disc error
I have the same problem, sometimes it works sometimes does, i have tested dvd always work on other dvd player, i am not happy with magnavox. ron
May 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Mine does it to and it has happend so much that i started slamming the top down to get it to play, its broken. Mines a magnovox from walmart.
Dec 26, 2007 | Coby TFDVD5000 Portable DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Magnavox 26MD255V/17 dvd player
buy an external DVD player, save yourself time, money and frustration.
Nov 13, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Electro Med Services...
