Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi Ultravision 50vg825 picture dims after It has been on
The picture on my ultravision 50vg825 starts out bright, but after the tv has been on for a couple of minutes it dims. I have messed with the setting in the video menu and that doesn't help. And, yes, I have checked to make sure it isn't set to the preset night time setting :)
  • nnjohnson Dec 01, 2008
    Mine is a 50" rear projection LCD. Sometimes it is only on for a few minutes when it dims, I also noticed that when ther is a blank screen that it usually has a blue tinge but if the picture is dimmed it has a grey color to it.
4 Suggested Answers
SOURCE: hitachi ultravision tv
watching tv when electricity went out everything came back on except tv
Posted on Jan 19, 2008
SOURCE: TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Posted on Nov 19, 2009
jhinsincity
  • 616 Answers
SOURCE: My Hitachi UltraVision HDTV won't turn on. The
Convergence has failed. $250 - 300 let a trained tech. do it for you.
Posted on Mar 16, 2010
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision 50V500A screen dim
The model indicated is a DLP rear projection and uses a "lamp" for brightness.
If it has not been changed for a while it should be on the right side of the set behind a removable plate. Check your owners manual if you have it.
Life span varies but 2,000 hours is normal.
Let me know if you need any further assistance as I am here to help.
SD TECH
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
