Question about EliteGroup P4VMM2 Motherboard
P4vmm2 doesnt boot,Y?
Anybody can help me pls. cause my computer doesnt boot when I power it on.I dont have knowlegde about this so that I want advice or solution from the other who have knowledge about this.thnx,,,,,,,,,,,,,,,,,,,,
  • 624 Answers
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Posted on Jan 13, 2007
My Desktop PC don't display anything during Boot process my MotherBoard is P4VMM2 REV. 8.1
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 22, 2011 | EliteGroup P4VMM2 Motherboard
After setting the bios for formatting my ecs p4vmm2 v5.0A hangs up what could be the problem and solution for this problem pls help me...
I had that motherboard, wasn't happy with it at all.
But you can flash the BIOS if you want . Make sure you download the correct BIOS version. There are like 10 versions for P4VMM2. I chose the wrong one last time my system didn't boot. I threw the motherboard away, purchased an Intel Motherboard.
I'm not a ECS fan at all. Use AMI flash utility , flash the BIOS under Windows.
May 08, 2010 | EliteGroup P4VMM2 Motherboard
Dell 1501 vios2.6.2. reads missing operation system..then after 18 seconds it shutdown..pls..help... anybody has many opinion to fix it i appriciate it very much. tnks..
Missing operating system errors generally indicate a hard drive read failure. This could be for several causes.
  1. Hard drive failure (Run diags on the drive, if you get an error code, then time to replace)
  2. Software corruption (Too many possible causes to list
  3. Virus
So run Diags Fn+ Power, see if HDD passes diags, if it does, then boot to your windows CD and go to recovery console in XP, (Repair My Computer in Vista/7) in recovery console, run the command CHKDSK /R
If that doesn't resolve, then try a repair install of windows;
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Dell Inspiron 1501 Notebook
I wont to overclock my old p4vmm2 and thr bios is LOCKED
******* ****** u **** my vista activation and i dont have the cd case so ******** ******* noob
Jul 11, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
My problem is control panel conector
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
If that's not it, check their US site. That should be it.
Feb 21, 2009 | EliteGroup P4VMM2 Motherboard
NEW MOBO MSI K9N SLI V2
the short answer is YES you need the additional power to the 4 pin molex.
Post your power supply brand and specs along with the copmplete spec of your PC and I'll be able to give some further advice regarding best option for you
Jul 16, 2008 | Intel Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
94 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
