"disk error" occurs when disk is inserted
Toshiba dvd SD-2900 says "disk error" when disk is loaded. The player is only a couple of years old and rarely used. We have tried different dvd's, with the same results. I have the manual and there is no mention of 'disk error'
  • 4,806 Answers
The drive cannot read data from the disk, follow these instutions:
if you are using vista, right click on "computer" then select "manage" then select "device manager". look down the list until you find CD/DVD and click on the + icon next to it, then right click on the CD/DVD and select un-install (make sure that there is a disk in the drive, preferably a movie or music CD) then restart the computer, when the computer restarts vista will detect the drive and install the drivers again, look in computer to see if the disk has been recognised
let us know how you get on
and please remember to rate us
regards
Posted on Nov 28, 2008
Disk error after loading. Tried several discs but get same results???
This one is shot. You can buy a new reader and replace it but most cases it is just not worth the hassel vs the cost savings.
Apr 06, 2016 | Toshiba SD-2900 DVD Player
Dvd will not load just keeps flashing loading This includes any type of dvd. Anyone have an idea to get this thing running?
try a few different types of media....if still no luck then your going to need some laser servicing or possibly replacement. same old same old im afraid. if the unit is more than a couple of years old then be carefull how much you spend for a service. may not be worth it.
Aug 02, 2009 | Toshiba SD-4100 DVD Player
Get Disc Error on display when loading a disk
you have problem with EPEROM IC you have to bring your set to toshiba repair center and they give a new program to your set . the program of your set is defected must be repaied
Mar 13, 2009 | Toshiba SD-3990 DVD Player
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Disk Error
You can not fix this problem because the player does not read dvd recordable disks
Sorry!
Dec 18, 2008 | Toshiba SD-2700 DVD Player
Toshiba Sd2800
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
Dec 09, 2007 | Toshiba SD-2800 DVD Player
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
Error message
i think your problem is that your lens( laser lens) that reads the disk is dirty. Try this get q-tip and put just little rubbing alcohol and clean the lens.
May 30, 2007 | Toshiba SD-K620 DVD Player
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
Electro Med Services...
