Question about Jensen JPA285 Car Audio Amplifier
Amp problem ok so i initially touched two wires together and of course the amp shut off and i let the amp sit reset itself for a coulpe of hours and it worked again but once i got the wires hooked up i started to turn up the radio and the amp cut out and wont turn back on,  i turned off the car and then turned it back on and the jenson light on the amp was on (very dim), but the power light for the amp was off and the stand-by light wasnt even on so whats the diagnosis for my amp doc? did i just loose my amp or what?
    Problem Solver:
  • 19 Answers
Check connections/wiring before ditching the amp. May just have gotten a loose or bad connection, or may have a short-out somewhere that got disturbed if you were driving it, or tucking wires away.
Posted on Dec 03, 2008
  • 1,066 Answers
Its fried, yo!!! you prolly fried the main capacitor, so it may be repairable, but costly. if you fried an ic chip, just forget about it.
Posted on Nov 28, 2008
Cannot open door after cleaning. Buttons are not responding to a touch
Silly answer but have to ask.
Have you unplugged the oven for 10 minutes to reset it?
Mar 27, 2016 | Ovens
My Rockford 500 A2 amplifier shuts off after playing music for a while and then after a little bit turns back on by itself. The power light goes out on the amplifier when this happens and when I touch the...
Make sure the amp is well ventilated, it needs to cool down or else it will shut itself off, then when it has cooled off enough it will turn on again. Also, check your wires especially your power wires. Make sure that they are the correct gauge. If everything looks ok then there may be a fault in the amp.
Sep 18, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
My reciever went to protect mode after my speaker wires touched. I removed all cables and power for an hour but stays in protect mode. I also changed 2 15 amp fuses inside but nothing unless I take fuses...
Yes, you can do this easily.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
Nov 23, 2017 | Onkyo TX-SR806 Receiver
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
I have a recently purchased RS 2664 RCA shelf
If the wires got crossed and/or touched each other at all - that could certainly damage the amp(s).
Also - if the system is not made for extra speaker - that would change the ohmage - and that could aslo damage the amp(s)..
Or maybe the system designed to protect the amp(s) was damaged..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Audio Players & Recorders
It shuts off right after I turn it on.
It's usually a component failure in the power amp section.
There are good tech shops in Cailfornia
Mar 24, 2009 | Denon AVR-1508 Receiver
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
I touched two speaker wires together and amp will not respond
That is a very nice amp . Try not to touch (short) those wires together. But yes, the amp has protection and is shutting off to protect it.
Nov 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Jensen JPA285 Car Audio Amplifier Logo
139 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
