Question about IBM Infoprint 1332 Laser Printer
Paper jam The paper jam message always appears even the paper was alraedy remove and even when i cancel job.
    Scholar:
  • 174 Answers
Disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.Make sure the unit is connected directly to the walljack.
Posted on Nov 28, 2008
Where is the cancel button?
Most printers don't have a cancel button. You get to "cancel" by going into your computer START menu then selecting CONTROL PRINTER then select CANCEL PRINT JOBS. In the future, I found the safest way to avoid accidentally printing more than intended is to always select "Current Page" when ordering a print job.
I hope that helps.
Mar 03, 2015 | Canon PIXMA Office Equipment & Supplies
Screen reads paper jam even though there never was a paper jammed. I tried turning the printer off and on but the same message still appears. Also the cancel ! keeps flashing even though I cancelled the...
Hello Sande.
Try cancelling the printer job via the control panel in Windows.
Also open covers, including the top flatbed half, to view the paper path.
There may still be a stray piece stuck in there somewhere.
Does this help?
Clive.
Nov 18, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
I am trying to print a copy and I keep getting message.... Paper mismatch. Try changing the paper type/size or paper in tray. I am using the same 8.5x11 paper I have always used. Reference guide does not...
Check your printer preferences. Check inside the printer if it has some paper jam.
Cancel all your printer jobs, turn off the printer - Turn on the printer and try again
Oct 08, 2008 | Konica Minolta magicolor 2300DL Laser...
Canon ImageClass MP730 - Clear paper jam
Were you doing duplex? take out the duplex and look in side and UNDER it
Nov 18, 2007 | Office Equipment & Supplies
IBM Infoprint 1332 Laser Printer Logo
137 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
