Question about Carrier Heating & Cooling
Carrier 58MVP; Blower on, no heat. Themosta at 75, temp at 69 and furnace still does not come on. Fault code 12
  • 1,420 Answers
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Posted on Nov 28, 2008
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
Feb 13, 2010 | Heating & Cooling
Old (20+ yrs.) Bryant-Carrier 397HAW060140 Furnace Fan Stays On
Its a bad high limit temp switch or sensor in the furnace that is out. The sensor is telling the board that the heat ex-changer is not cool enough to turn of the fan. www.fastacservice.com
Oct 17, 2009 | Heating & Cooling
Bryant-Carrier Furnace Fan Stays On
Its the Relay on the circuit board trust me...is it a 58SX????.....very common...
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas furnace continually running
Is the blower operating and are your air filters new
Jan 03, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
On off cycling, little air flow, little heat
We had the same problem with the same furnace, CODE 32 DISPLAYED ON THE LEDS. I fixed it by cutting the air inlet pipe and using a hair dryer to supply heated combustion air to the furnace. Once I did that it started to run more and more until it finally heated the house up and works fine, so far so good.
We had a severe drop in temps, sunday it was 40 and rain and that night it dropped to -5 I suspect those conditions contributed to the problem. Wife observed this has never occurred before in 14 years of operation.
Nov 13, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
685 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
