REINSTALLATION PROBLEM I am reinstalling my Brother MFC-8840D. The PC is now able to print to the MFC (connected via USB) but the Scansoft Paperport wouldn't install. I tried Uninstalling but when I tried to re-nstall the only choice is REPAIR OR REMOVE. BUT my main problem is that I cannot see the MFC under Scanners and Cameras. What do I need to do to fix this?
jackboy
  • 2985 Answers
SOURCE: reinstalling 2400 scanner driver
If this scanner was previously used on a Win95/8/ME system the likely hood of it working with and NTFS[3000/XP] system is slim. This is because the two system work in different ways and the scanner design for 95/8 does not recognise commands from a NTFS computer. Two thing to try Go to Mt computer/Help/Compatibility and read it up. then right click on the scanner software and click on properties/compatibility and set it to Win98- see what happens You could checkout Xerox for driver updates also. But don't hold your breath
Posted on Sep 07, 2007
SOURCE: mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Posted on Mar 02, 2008
BFixed
  • 104 Answers
SOURCE: Scanner connected to USB port but will not operate
Look here for drivers
Posted on Mar 11, 2008
rickyostrom
  • 274 Answers
SOURCE: ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
  • 320 Answers
SOURCE: Problem reinstalling Brother MFC 8440D.
uninstall the brother software for this machine, then reinstall the softeware. the paper port some times will install automaticly or you may have to click on iy to indtall. brother tech
Posted on Jan 14, 2009
Would like 2 copies of a fax
Is it a fax you received? Well, if so, open it using Scansoft Pageviewer. Unfold the File menu and look for the submenu print. Send the page to the printer or open the configuration panel of your printer and set the number of copies to 2 or any other number of your choosing.
If you do not have the MFL Pro Software Suite that relates to your printer, download it from Brother Solution Center. Choose the version that is specific to your OS. As to the Scansoft PaperPort software, it is not available in the download and you will have to use the Disk that shipped with your printer.
Another pedestrian way to solve the `problem` is to print the fax once, then feed the copy just made to the copier. Your MFC is able to copy documents.
Jun 18, 2012 | Brother MFC-5440CN All-In-One InkJet...
WE now have Windows7 and the printer will print, but you can not scan. It did scan once, but we never found the document we scanned which usually went to My Pictures when the other computer had XP. ...
Hi there!
If you just upgraded your operating system. What you can do is to reinstall the full driver & software package using the CD. You can also install Scansoft Paperport which is a software bundled with brother that you can also use for scanning. Reinstalling everything from the CD should do the trick.
Hope this helps. Please rate if it worked Thanks!
Mar 30, 2011 | Brother MFC 490cw Color Inkjet...
How di I reinstall PaperPort Print Driver? PaperPort 11, Windows 7
Instructions extracted from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
"{Ok, here is how I got the whole package from my Brother MFC and PaperPort 11 with the printer utility.
First if you have tried to install the suite or paperport and are having issues uninstalling through windows download this wonderful program that removes everything called Revo Uninstaller at www.revouninstaller.com and choose the freeware version.
Now go to the Brother website and search for the Windows 7 MFLPRO Suite and you should download a zip file that contains the suite for multiple MFC’s. Unzip it and set it aside. This is only the Brother Suite for the Brother MFC and the Control Center 3.
TO find the Windows 7 version of MFL PRO go here
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=5
PaperPort 11 will have to be installed from the actual CD that came with your printer. Inside the CD with Windows Explorer File System locate the file Inst32.exe that should be inside the CD under the install folder then MFC-465CN (my model) then usa folder. Remember the location.
Now set everything aside and let’s start. Open up control panel, click on programs and features then choose Run programs made for previous versions of Windows. You have just opened up program commutability, now click next and wait now choose not listed and press next. Browse and fine the Inst32.exe file that I mentioned earlier. Now click next and then choose Try Recommended Settings, Next your setting should say applied and compatible with Windows XP SP2, then you will see a tab on the next screen that says Start the program. Click on it and allow it to start installing this will start the suite and the first thing that installs is PaprPort, be patient let it continue to run and after it will install the PaoperPort print driver, then after it will start into the MFL PRO Suite. This is where my installation halted because the suite is a 32Bit version it would not continue. I looked and PaperPort program and printer where installed. Close it up and pres next.
Finally now you can install the MFL PRO for Windows 7. Open up the folder you downloaded from Brother and look for your model and you will see the setup.exe application, click on it and start installing MFL PRO along with Control Center 3. That’s it, and your setup should be complete.}"
Hope the thread from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
will help.
Jul 21, 2010 | ScanSoft Nuance PaperPort 11 for PC
Just got a new computer w/windows 7 and now my brother mfc-8840D won't scan to pdf now? Any ideas on a solution to fix?
How to get a MFC-8840/D/DN to scan to Windows 7 over the network or by USB:
First - Download the Windows Vista Full Driver & Software Package from Brother: Brother MFC-8840DN driver download page
Install the drivers using a custom install - pick only the Network scanning drivers, unless you want the other junk - no promises on how well the other stuff works.
Alternatively, if connecting the MFC-8840DN to Windows 7 by USB, download the Printer and Scanner Driver for Local Connection. It is a separate download. Install only the Scanner driver.
Once the Vista scanner driver is installed, you can test by running the built-in Windows 7 Scanner Wizard. Here are instructions on how to test.
As far as conversion to PDF, that will depend on the software. I am not sure if the Control Center or Paperport softwares work on Windows 7. I have not tried those. I have found that freeware STP will works fine.
Here is a link to the STP homepage.
Here is a link to how to use STP with the Brother MFC-8840DN
May 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Feb 25, 2009 | Brother MFC 8840D All-In-One Laser Printer
HOW TO USE THE SCANNER ON MY BROTHER440-CN USB
Normally , Brother software disk have SCANSOFT PaperPort can receive you scan , other you can use word, or photoshop to receive you scan.
Jan 31, 2009 | Brother MultiFunction Center MFC-440CN...
Dec 02, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
Feb 28, 2008 | Brother MFC 240C All-In-One InkJet Printer
k24674
jasbo
jasbo
Marvin
Marvin
