Question about Canon Cameras
Will I damage my Canon IXUS 75 camera by using a SanDisk 8GB SDHC card.
    Problem Solver:
  • 15 Answers
No
Posted on Nov 28, 2008
My canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Can i use 8GB SD Card on Canon IXUS 80.?
Technically no, since SD cards only go up to 2GB. However, the IXUS can use SDHC cards up to 32GB.
Aug 09, 2011 | Canon IXUS 80 IS Digital Camera
Can I use a "SDHC"
Hi
Sure you can as it supports SDHC cards too.
Jul 21, 2011 | Canon PowerShot SD1100 IS Digital Camera
Hi there! I have a Canon PowerShot SD700 is. I have bought a Sandisk 8 GB. My camera cannot read it. It says: Memory Card Error. What can I do about it? Many thanks for your help
The SD700 works with MMC and SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
Apr 23, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Will the canon ixus 30 use a 8GB SDHC memory card, as it shows card locked in display
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 11, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
My canon ixus80is
The Digital ixus 80is is fully SDHC compliant so should work with all SDHC capacities. There are no reports yet of incompatibility with the larger capacity cards as long as they have been supplied from trusted sources.
Every SDHC compliant camera which I've recently dealt with has only had problems when fitted with cards from suspiciously cheap suppliers. If an SDHC card is too cheap then it's almost invariably counterfeit and what's inside the card does not match the label outside, often they're plain low capacity SD cards.
As long as you stick to major brands from trusted sources you should be OK but bear in mind that the 16GB SDHC variants slow the camera functions down significantly compared to using an 8GB model.
I hope that you've found my answer to be of use and ask only that you return the favour by rating my answer.
Oct 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Reformatting sd memory card for canon camera an 8gb card and it told me I coudn't print pictures on my HP photosmart 380 series printer unless I reformatted my memory card??
If your camera is indeed an SD200, am sorry to say an 8GB SDHC will not work in this camera. The camera will fail to recognize it, and will do this by giving various problems as you've run into. The overall problem is that the camera was designed before the SDHC format came out (SDHC cards although the exact same in appearance are different in format than standard SD cards). The largest size card that the SD200 will recognize is a 2GB standard SD card.
Jun 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Card locked canon powershot sd750
Check the switch on the side of your SD memory card. It is a small sliding switch which has a lock position. Sounds like the switch is in the "locked" position. Unlock, reload card, & you should be good to go. If not, the card is probably damaged.
Mar 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
