Question about Speed Queen AWS52NW Top Load Washer
Water runnning out from bottom of washing machine
Filled washing machine. Heard slight drip - looked around and couldn't see anything. Washer went through cycles. When ready to add Downey, saw water on the floor below washing machine. Took everything out of washer and tried to get water out too. Do I need to get a new washing machine? The one I have now is almost 16 years old. It is a GE 7 cycle machine with mini-wash. Thanks.
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Posted on Jan 18, 2009
1 gallon of water leaks out the bottom (overflow?) dripper with every load.
your pump seals are bad,this is a cover to keep the pump dry if something up above leaked,but from the pics it looks to be the pump especially with all the water leaking,just replace the pump unit
May 04, 2012 | Kenmore 98702 Stacked Washer/Dryer
My Whirlpool Cabrio is so out of whack that it will not wash a single load without going of balance. I am generally a Mr Fixit, so with the help of some web advice I opened the top and I removed the wash...
yes the balance ring is supposed to be filled with glycol..... these washers cannot runn bulky loades or single articles of clothing.... if the load your running is not coating the drum evenly the all the weight is going to be on one side of the tub which is going to spin vigrously uneven,,,
also cabrio washer top lids are very slanted which means u cant level the washer by using the top of cabinet .... put level on each side use split of cabinet top to bottom of cabinet as your straight edge for placement of level ... theb level front to back and left to right and check other side ... if it checks out level....then take a clear cup fill 3/4 with water and place 2 feet infront of washer and start washer spin cycle if you see any ripples in water in cup while washer is spinning the reinforce floor joist under washer ...
Jan 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Kenmore front loading washer. I normally leave the front door open when not in use. I came home the other night to water dripping from my dining room ceiling (Washing machine is on second floor...
The water solenoid could be defective. A solenoid is an electrical switch that pulls a shaft out of the water line to let the water flow in. The timer controls this along with water level sensors. That solenoid is a big electric magnet that operates when the power is applied to the electric coil and it snaps the shaft out of the water line allowing water to flow. It also compresses a spring around the shaft and when the power is removed from the coil, the spring snaps the shaft(valve) back into the seat of the water line. If the spring is weak or broken or blocked by debris from hard water, it does not close all the way and allows water to leak. Very similar to a leaky faucet.i expect that the solenoid will have to be replaced.
Jan 11, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Whirlpool Duet washing front loading washing machine. I have had it for about 6 years. All of a sudden, about a month ago, it filled up with water while off. The door was slightly ajar since I...
Yes, this is actually a common problem when either the pressure switch malfunctions or a water inlet valve that is leaking by. The following link explains how you can determine which one may be causing your problem:
Check the small air hose that runs from the bottom right hand side of the wash tub to the pressure swtich. If this hose has come loose from the pressure switch from the air dome on the wash tub, the pressure switch will not sense the pressure differential coming from the wash tub as the unit fills. Also, if the air hose is cracked, ripped, split, or clogged somewhere, you will get the same symptoms.
If the water inlet valve is determined to be the source of your problem, follow the steps provided in the link on how to replace one. These are simple and inexpensive repairs. I've also included web sources that you can refer to for part numbers.
If you need further assistance, please post back and let me know. I hope this helps lead you in the right direction.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Washer loads with water but wont drain.
A lot depends on your model. Several different setups out there Todd.
Sep 18, 2009 | Washing Machines
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Apr 25, 2009 | Frigidaire GLTF1240A Front Load Washer
Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Speed Queen AWS52NW Top Load Washer Logo
294 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
