We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top and seems to be "shrinking" down in size. We have had them come and change out the cable box 2x and switched one of our other tvs in place to see if it was the tv or cable box. The other tv worked fine on this cable box so we think it's this tv which we bought in 1998.
    Scholar:
  • 135 Answers
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Posted on Jun 02, 2017
tvtechnician
  • 105 Answers
SOURCE: sony LCD tv
you are going to need an optical assy (A-1084-658-A) and it runs about $1257.50
Posted on Oct 13, 2007
Slinteriors
  • 8617 Answers
SOURCE: Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
SOURCE: picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Posted on Mar 01, 2009
  • 21 Answers
SOURCE: how much is a power board for a tp50h95/tp55h95
bluestar international has one for 145.00 and 13 s&h they have all you hard to get parts that repair guys overcharge for ,they take paypal too http://www.bluestar-online.com/SearchResults.asp?Search=STK392-040&Search.x=12&Search.y=16 search here for your parts
Posted on Jul 13, 2009
I Have a major convergence problem. It is a 55 inch Toshiba ColorStream Projection TV(tp55h95). It was fine until we moved it into the other room, and now it's like the color is bending at both sides of...
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
Aug 06, 2010 | Toshiba TP55H95 55" Rear Projection...
How much is a power board for a tp50h95/tp55h95
Jul 13, 2009 | Toshiba TP50H95 50" Rear Projection...
TV will not turn on
the convergence amps might need resoldered. thias is a common problem after the run for a few years
Jul 10, 2009 | Toshiba TP50H95 50" Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H95 Convergency problem.
Hi. The covergence Ics are mounted on large heat sinks they usually start with STR**** You will need to replace both & check resistors electrolytic capcitors & any circuit protecters on the same pcb as the chips.
Sep 02, 2007 | Toshiba TP50H95 50" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
