Samsung HPS4253 Sound but no picture.
The TV responds to the remote and powers up, the 'on' jingle sounds, and the picture stays black and blank. It will stay in this state for about 20 minutes then it powers itself off. There is no menu nor any sort of screen function. The sound seem to be working fine. Any suggestions or help in where to start or what to replace first?
  • 3 more comments
  • Axle80
    Axle80 Dec 10, 2008
    So is this a screen replacement? Where is the backlight to be replaced? I started testing the PSB and found a dead fuse, when I replaced it and plugged it in I sent a shower of sparks into the ceiling, the PSB is deffinately cooked now....I'll start by replacing it then move on to the light if you can give me a heads up where it is.
  • Axle80
    Axle80 Dec 11, 2008
    Wait...do plasmas have backlights? I know LCD's do, but after doing a little more research, I think you're wrong. I can't find any mention of a backlit plasma TV....anyone got a clue what I am rambling on about?
  • Axle80
    Axle80 Dec 16, 2008
    SOLUTION!!
    I went back to the source of the problem....the power source, or Power supply board. Using the factory test points on the board, small silver tubes with a hole in the top, about the width of a pencil lead, I checked for correct voltages. The correct voltages are on a sticker on the back of the screen it self, with values like Va and Vsc etc. As I checked the points I found the Va was supposed to be 65 and was reading at 4. I followed the va lines back and thats when I found the blown fuse, and after replacing the fuse, doing a component reassemble, and re-creating the 4th of July in my workshop, I replaced the Main Power Supply Board. Wallaa the voltages returned to normal, all the other boards and LED's went on correctly, I reassembled and the screen fired right up. I am soak testing now on Xbox live. 2 hrs and going strong! I would be happy to help any one else out there with this TV. I ended up replacing almost every board and now know this set inside and out and better than my...well you get the point. Good Luck.
  • photo_beyond Mar 18, 2009
    My power supply seems to be bad. It makes clicking noise and the tv will not power on. How do you check the voltages on the test point? When using a volt meter, what do I set it on? Do I set it to VAC or VDC or something else? I touch the positive on the test point and where do I touch the negative? Do I just touch the negative to the metal frame? When in VDC mode, I get a reading of .395 volts and .190 on the other. Does this confirm that it is bad since it is supposed to read 210 and 63?
  • Axle80
    Axle80 Mar 23, 2009
    Put the multimeter on VDC 200 for all the points except the highest volatge one, which will need the 500 setting. Use the red needle on the board and ground the black one anywhere on the metal frame. Make sure the tv is on when you do your testing, but be really carefull, you could fry a lot more than just the tv. If you can't find the points to test them all, email me and I'll send you pictures or video of where to find them and how to test. Cfoley@hawaii.rr.com
    Genius:
  • 1,066 Answers
Your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
Posted on Nov 28, 2008
I have a Samsung PN51E530A3FZXA 51" plasma TV. I heard a pop & saw smoke from left rear of TV. TV went black & had no picture or sound, however the red power light stayed on.
Unfortunately plasma tvs are a lot more complex to service, instead of 2 or 3 boards there are a half dozen at least. I would guess when the main PS board went out it took some other boards with it. I don't have a manual for your set but I would look at the power supply sub boards, there generally are 2 of them, or on some models that is parts of the other boards. Generally there is a legend to see what voltages are supposed to be present at what places, samsung is good about making the test points on the boards. Also there are fuses on most the other boards and its possible one of those has blow, it won't be a typical fuse like your used to seeing, some are a small green component and some are white mini fuses...Good luck!
Nov 10, 2017 | Samsung Televison & Video
Im having a problem with our Sony Bravia T.V. When we turn it on the light goes green but the tv stays black, no sound either. Cant turn it off with remote or on TV. The only way is by unplugging it.
Most likely the power supply board needs to be replaced. The fact that both the sound and picture don't work really points to that board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Nov 14, 2016 | Sony Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Smoke from plasma TV
Sounds like you will need a new power supply board you can get the power boards from www.tvrepairworld.com which also has instructions for replacing the board. Just hit the contact us button on the right side then enter your model number and symptoms a samsung tech will respond via email to assist you with the issue.
Jan 23, 2012 | Samsung 50 in. Plasma TV
Televison & Video Logo
1,219 people viewed this question
Top Televison & Video Experts
