Dvd player will not detect disc - Computers & Internet
  • Simon Kelly
    Simon Kelly May 11, 2010
    any disc? ensure it is install correctly by checking it's status in device manager - start-> run-> devmgmt.msc
    and have a look in cd/dvd rom drive or similar. This should display the brand of DVD player that you have. please let me know the model number and brand.
  • Howard Lester May 11, 2010
    Just one particular DVD or every DVD you put in? It makes a big difference how to fix it.
  • 4 Answers
Lens problem or dvd stip problem
Posted on Nov 28, 2008
My brand new dvd says no disc on any disc i put in
hi check the region code compatibility of your player and also the CD format..DVD players are equipeed with region code detection you can play DVD which are local to your location or to where you purchased your player...
Jun 06, 2012 | Philips Televison & Video
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
My philips dvd player is not detecting any cd or dvd, it is saying no disc after a long wait. Any idea in this, please help.
well try to purchase a dvd lens cleaner and insert it into the player for cleaning. After that process has been executed you can now insert your choice of disc for play..
Jul 23, 2010 | Philips DVP5140 DVD Player
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
WILL NOT DETECT INSERTED DISCS
Lens dirty, have lens clean with DVD lens cleaner.....
Sep 07, 2009 | Panasonic DMR-E85H DVD Recorder
Same problem
oh my frd...it happens bcoz u could hav burned u r cd in data files format...wch will not detected by the cd player...cd player detects only the mp3 formats...so nxt tym u burn a cd check whether the option wch u given s mp3 format for audio files...and main thing is that check whther u burned a CD or DVD...bcoz CD player will not detect DVD...a DVD player can detect CD whereas CD player cant detect DVD disc my frd!!!!
Jul 24, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
NexxTech DP3222 DVD Player
Try a Laser Lens Cleaner disc.
It is a CD with brushes on the bottom to help clean the laser lens (used for reading discs).  It can be found cheapest in grocery stores, then office supply stores, and finally most expensive in electronics stores.  It will usually run you about five to ten dollars,and can be used multiple times on any disc drive.
Aug 13, 2008 | NexxTech DP3222 DVD Player
Cd burner--dvd player---vcr/dvd recorder/vcr
The disc isn't a compatible disc???????????
Nov 26, 2007 | Panasonic DMR-E55 DVD Recorder
UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Nov 24, 2007 | Philips DVD750VR DVD Player/VCR
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
