Question about Dryers
Dryer won't spin
My admiral dryer won't spin heats up ok
5 Suggested Answers
  • 178 Answers
SOURCE: WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Posted on Apr 09, 2008
david04928
  • 102 Answers
SOURCE: heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Posted on Mar 16, 2009
mnwarfield10
  • 452 Answers
SOURCE: The dryer won`t heat, it
CHANGE THE ELEMENT AND STATS ..
Posted on Feb 27, 2011
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
I have a admiral dryer and it quit working today had ahot wire smell and now it will not do anything bracker os good.
Sounds like the heating element may have burned out. I assume the drum still spins??
Jan 24, 2017 | Admiral Dryers
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral dryer
If its a gas dryer your dryer vent might be plugged up.
That would be the first thing I'd check if it were me and if this is a gas dryer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 21, 2013 | Dryers
My admiral heats up but doesnt spin found the problem its the belt but which way does idler wheel go
If you are referring to the spring loaded tensioner it goes on the smooth side of the belt
Feb 03, 2013 | Admiral Dryer Belt 31531589
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
My admiral designer series electric dryer is not heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 24, 2010 | Dryers
Dryers Logo
161 people viewed this question
Top Dryers Experts
Marvin
Marvin
