Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Not getting water out of dispenser in door of GE Profile Refrigerator-Think Line may be frozen
  • 74 Answers
There should be a connector at the bottom of the door , if you get water to here but not through the dispenser then the line is frozen in the door . This can sometimes be cleared by connecting a steamer to the pipe and letting the steam thaw the ice blockage but this will not generally be a permanent repair . If water is not getting to the connector then it may be a frozen water tank in the fridge compartment or a faulty valve
Posted on Nov 28, 2008
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My water dispenser will not dispense water. I
you just need to defrost turn off fridg. over night it is frozen in the frezzer door
Feb 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water does not dispense
there should be a water line that runs from the reservior that is in the fridge compartment under the appliance to a connector at the bottom of the freezer door, if water is getting to there then the water line within the freezer door is frozen . If water is not getting there then the reservior may be frozen or the watervalve may be faulty
Nov 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
225 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
