Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Not getting water from dispenser in door
Ge Profile side by side refrig-Model PSS25 mgnaww
    Problem Solver:
  • 6 Answers
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Posted on Jun 08, 2012
  • 74 Answers
If you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Posted on Nov 28, 2008
Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not coming out from water dispenser
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a heater which is easily installed , to keep this from happening again pt # WR49X10173
May 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE SS Side by Side Refrigerator is not dispensing water; makes ice just fine. Is this a problem that I can fix without a service call?
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Dec 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
740 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
