Question about Indesit W 123 Front Load Washer
My Son's guitar picks (Now about 20) are stuck between the two bowls of our front loader. They make a racket when machine is starting to spin. They are not getting down into the pump for some reason and the machine is working ok otherwise. I have tried forcing air (into soap draw with front door closed) and vacuuming at the pump outlet at the bottom of the outer bowl but have had no success. Do you have any suggestions in getting them out, short of dismantling the seals and bowls? Regards, Phill
  • 116 Answers
MAY HAVE TO OPEN UP TUB AND REMOVE ALL DEBRIS FROM INSIDE ,,,,,REMOVE ALL BOTTOM CLIPS ,, DO NOT RECOMEND YOU TO DO THIS NOT EASY
Posted on Nov 30, 2008
Washing machine will not spin at the rinse cycle
front loader belt driven ?
even a clutch system
if water is still in the bowl it wont spin
could be a water pump or water level issue
or timer or control board
Jul 04, 2016 | Kenmore Washing Machines
Tip
THANK YOU SO VERY MUCH!!! This worked perfectly. Found lots of coins, my son's...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My front loader fills with water but then does nothing. The drum doesn't turn. Can hear clicking sound from the control panel as though it's moving through the cycle. Checked the belt and is in good c
Does it spin if you turn to spin cycle?
Try this:
Jam lid switch with something plastic or wood.
Put on spin cycle.
Spin the tub by hand.
If the bowl then starts spinning properly, your problem is the motor starting capacitor.
May 21, 2014 | Daewoo Washing Machines
Washing machine not spinning properly
indicates that the suspension rods ( top loader ) or bearing supports ( front loader ) need replacing as the bowl is not level
Jun 24, 2017 | Zanussi F1245W Front Load Washer
Washing machine is off balance
Not fixed but it still goes so I guess i'll just keep using it till it breaks down altogether
Nov 08, 2009 | Washing Machines
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Fisher & Paykel no spin, no rinse
hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Mar 22, 2008 | Washing Machines
Ge front load washer, 7 years old
speed control module faulty replace it .Close Ireland bye bye
Nov 22, 2007 | GE WSXH208A Front Load Washer
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
