Vicks V3100 1.2 Gallon Humidifier
Problem for Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
By connollet on Nov 28, 2008
i have a this humidifier, i got it from a friend. i dont think it is missing any parts, but the tank leaks, it will not hold water at all, how can i fix this.
Same Problem
Jan 05, 2009
-   I have the manual but it does not address this issue. I have scoured the internet looking for a solution.-   Guest
Dec 30, 2008
-   I have the same problem. My humdifier (same model as yours) began leaking suddenly after one year of ownership. I just noticed the hole too. I think that the valve at the bottom of the tank is faulty and causing water to stream into the pan. Like you, I don't know why that hole is there. -   mcruiz505
Dec 02, 2008
-   I have had this problem for about and year and never had any problems. It started leaking yesterday. I turned it over and noticed that it has a hole in the bottom of the unit. The hole is uniform,so it looks like it has probably alwas been there. i don't think I've lost any parts, like a plug. Does anyone have a manual for this product?-   rbten
Best Solution
posted on Feb 05, 2009
Very Helpful)
AVGIV
Rank: Apprentice
Rating: 100%, 4 votes
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 02, 2009
Not Rated)
rivenbarks
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. Turned out to be a bad seal on the cap. I found a customer service phone number for Vicks and they are sending a new cap, at my cost of $4. If I figure out where I found the number, I'll add it to this comment.
Was this helpful?
Yes
No
Popular Solutions for Vicks V3100 1.2 Gallon
Questions and Unsolved Problems for Vicks V3100 1.2 Gallon
Do you recommend Vicks V3100 1.2 Gallon Humidifier?
Answer
Answer
how do i use a vicks 3100 cool mist humidifier ?do i simply just fill it up with water or what do i... (More)
Answer
My Vick's V3100 has made a humming sound since we first bought it two years ago. We have 2, and the... (More)
Answer
I just bought the v3100-e humidifier, I filled the tank with cold water and switched it on, but no... (More)
Describe your Humidifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Humidifier Experts
Top Air Conditioner Repairmen
in , NY
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
