Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother printer MFC-440CN
The printer say unable to change 51 I have check the paper its not jammed I have unplugged it for a few hours no change i have cleaned the scanner no change help
  • Anonymous May 11, 2009
    I have printer dcp-350c, and have same error message.. can't do anything with it... Have you found an answer yet?
  • 28 Answers
Try to re_install the driver
Posted on Nov 28, 2008
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
I get this error code in hp 1312 error cod 51.23 what can i do i wait your answer best regard
Turn power off. Unplug printer. open and close firmly every door, hatch, panel, and drawer. Verify all toner cartridges are full. Verify that no paper is jammed in the mechanism. Power printer back on.
Aug 20, 2011 | HP Laserjet CM 1312NFI Color Printer
"Clean Unable 51" error. I
Click the link below to download the Service / Repair Manual ( Brother MFC-240C) :
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site
Jul 04, 2011 | Brother MFC 240C All-In-One InkJet Printer
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Unable to clean 51
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to visit your local Brother Authorized Service Center, you can find one by clicking here. Thank you for using FixYa! - Don't forget to rate our service.
Feb 02, 2010 | Brother Office Equipment & Supplies
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
The machine has a mechanical
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother LC-51 unable to clean code 4F
The code 4F unable to clean comes up for paper jam, if no paper jam,TRY THIS MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Hope this may help;
Jun 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
349 people viewed this question
James Cagle
James Cagle
Jim Keysor
