Question about TOPICS Entertainment Instant Home Design (CS-070) for PC
After Instant Home Design v3.0 CD drive Malfunctions
About 15 minutes after Startup my CD drive tray flies in and out in seemingly random jerks and a window with an Autoplay flashlight comes on the screen. It first happened after I ran this CD ROM.
I tried to uninstall and also refresh to an earlier date, but neither worked.
2 Suggested Answers
YaBaPortugal
  • 123 Answers
SOURCE: Instant Home Design will not install
you may need some VB Runtime files.
check these:
http://www.microsoft.com/Downloads/details.aspx?FamilyID=bf9a24f9-b5c5-48f4-8edd-cdf2d29a79d5&displaylang=en
Posted on Sep 15, 2009
CD Tray will not close
It sounds as if there is either still some obstruction within the CD tray mechanism or path, or else the CD drive itself has failed and should be replaced.
I would recommend replacing the CD drive, especially if it has already caused one CD to break into fragments.
Replacing a CD drive should be reasonably easy if you have a tower computer and are happy to open the case.
Depending on the design, there are normally only 2 screws on each side of an optical drive and 2 cables on the rear to disconnect (3 cables if you have a direct sound connection from the drive to the motherboard).
Some case may have a quick release method for removing the optical drive. You should consider replacing the CD drive with a combination CD R/W DVD drive unless you already have a second DVD drive installed.
Jan 17, 2012 | HP Computers & Internet
My CD tray will not after removing a fragmented disc that got stuck
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
SGI O2 CD-ROM drive tray repeatedly opens
I am having the same problem. I haven't resolved it entirely, but at least I managed to get it working again by the following steps.
First, disassemble the part of the computer chassis around the CD-ROM drive. Follow the instructions for "replacing the CD-ROM drive" in the SGI 02 hardware maintenance manual. It can be done in 10 minutes with a screwdriver.
After you have gained access to the CD-ROM drive itself, take off the top metal cover. Then you will be able to see the tray and the white gears underneath.
In my case, the problem seems to be caused by some misalignment between some wire springs and the white gears. Note when the CD tray closes, the manual eject button (a black plastic rod on the right) should stick out, and the white piece of plastic with a triangular end on the left should push against the front of the CD tray.
Somehow, the gears failed to push the white plastic piece all the way to the edge of the tray, and the CD-ROM drive thinks the tray wasn't fully-closed, and ejects the disc.
To force the drive to read the disc, pull the white plastic piece on the left with the triangular end towards the edge of the tray. (Pull it towards you if you are facing the front of the drive.) You might need to use some force, but I can get the drive to work this way, even though it still "sticks open" half the time.
Good luck, and if you happen to find a better solution, I look forward to hearing it.
Jan 07, 2009 | SGI Silicon Graphics (P-CDR32-EXT) CD-ROM...
Pioneer elite pd-f27 300+1 cd changer
I've owned two of these players, one currently, and both exhibit this behavior. Although frustrating, it seems to be inherent in the vertical loading mechanism. Every finicky CD I pull out of the PD-F27 plays perfectly in my single-loading tray player, including CD-Rs. One would expect more of an "Elite" product, but there you are.
Mar 17, 2008 | Audio Players & Recorders
Head unit randomly cutting out
hey gt: I have a similar problem with my JVC PDR 30 cd deck. It seems to happen in the hot weather. Tried the cd in my other vehicle and it works fine,, If I can find out more will let you know.
Jul 13, 2007 | JVC KD-G720 CD Player
TOPICS Entertainment Instant Home Design (CS-070) for PC Logo
66 people viewed this question
Top TOPICS Entertainment Computers & Internet Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a TOPICS Entertainment Computer and Internet Expert? Answer questions, earn points and help others
