Question about E-Machines eView 15s Monitor
No display from VGA adapter.
I have an eMachine t5020 computer with a 480 Watt power supply unit. The other day I tried to install my new nForce 570SLIT-A motherboard with a 8600 GTS video graphics card. The problem I'm having is my Compaq CV535 monitor gives me a black screen when I plug it into the VGA - DVI-I adapter. I don't even have to plug the adapter into the graphics card and when I do it continues to remain black. The motherboard seems to work fine and the computer turns on as well. The only problem is the monitor won't display an image. At all. Connected to the adapter or not. It won't give me an image. So I don't know what's happening or graphics card is working either.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
The graphics card won't initialize unless the system passes certain internal checks; most of the time this is caused by the wrong RAM configuration. Make sure the RAM you are using is the right type of RAM for your system; in some cases the system board will still power up with the wrong RAM installed. Then check monitor connection to make sure there are no bent pins on the connector. Furthermore, I'd even check to see if the system boots without any RAM installed.
Posted on Nov 28, 2008
Question about Dell D220P 01 Optiplex AC/DC Adapter 220-Watt Power Supply HOW DO I USE THIS UNIT TO PROVIDE 12V STANDALONE POWER?
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at
www.fryselectronics.com/computer/parts/power_supple/stand-a-lone/for_PC_use/220_watts/
type power supplies stand-a-lone 220 watts computers compatible
Mar 02, 2015 | Dell D220P 01 Optiplex AC/DC Adapter...
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
T5020 emachine seems to have dead power supply- how can I confirm?
If the PSU fans only work for a short time usually this means that the PSU is shot
If you suspect your power supply has gone bad, there are a few basic things you can do to test it. First, plug the computer in and try to start up the computer. If the computer can start up or shows signs of having power (the hard drives spin up, or the fans turn on) the power supply might be fine, and you may have an issue with your motherboard or RAM. If the computer won't start at all, open the case and then turn the power supply on and attempt to start the computer. Observe the motherboard to see if any lights turn. If no lights turn on and there is no sign that power is being supplied to any of your devices, there's a decent chance that the power supply has burned out. If your computer experiences periodic crashing, feel the case near the power supply to see if it is hotter than normal, and smell the air. If the case is much hotter than normal or you smell burning, your power supply might be overheating, and may be damaged. http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm hope this helps
Jan 01, 2013 | eMachines T5020 512MB DDR PC-3200 Desktop...
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
I want to install a gts 250 graphic card on my pc this card want a 8 pin wire and my power hasnt it there is a reduction which want 2 (6 pin) wire and my power has just one 6 pin wire can i use my...
No, if you attempt that then your computer with either not work because of video card errors, or it will boot up and run for a couple hours and then the graphics card will most likely melt due to insufficient power to the fan. Your best bet is to return the video card and buy a video card that is compatible, or buy a new power supply with the connections that you require.
Jan 13, 2011 | Intel Power 480W 480 Watt Pentium 4/ AMD...
What size power supply would fit an e-Machines EL 1333G-03-W Desktop. How high of wattage can the board take?
Your computer came from the factory with a very tiny 220 watt power supply that is about as small as it gets. This is what you get with inexpensive computers and the failure rate is always high as the power supply is usually over worked trying to keep up with the power needs of the pc. The board will use no more power than it needs so you can install a high quality power supply. So I would recommend you install at least a 400 watt power supply and a 500 watt would be even better. Just buy a power supply compatible with your PC. Here is one good source for power supplies. http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=106&name=Power-Supplies
Jan 05, 2011 | eMachines EL1333G03w (884483010820) PC...
Hello Guys, i my monitor will not display anything even if the system unit is running? and processor is abnormally heating, i just bought a new vga card and it started this, i have intel core 2 duo @...
hurm,try change the processor fan.. or your monitor did not support the vga card.... monitor have the resolution.. or you can change the power supply to 500w..
Oct 08, 2010 | CTX S762A 17" LCD Monitor
Just replaced power supply unit from a 250 watt to a 480 watt and now computer comes on but will go into power saving mode instead of booting up and keyboard doesn't stay lit like it used to.The system is...
Which power supply went bad? The 250watt or the 480watt? If a power-supply goes bad (dies), it generally takes some (if not all) hardware with it.
Jan 05, 2010 | HP Computers & Internet
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Won't boot
You will need to flash the graphics bios of you comp. Put the CD that you got along with the Card and reboot your computer and then follow the onscreen instructions to flash it.
Let me know if you need more help!
Regards,
Sai.
Sep 26, 2008 | Gateway 510 X (10272197) PC Desktop
E-Machines eView 15s Monitor Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
