Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I can't format the maxtor 3200
I deleted the partitions, but it won't let me format it
  • 4 more comments
  • John Bays Nov 28, 2008
    It won't let partition it either
    just data
    it totally disappeared now
    I got it back now
    Thank you mumma 1, you are a god send. J
  • Anonymous Dec 02, 2008
    go to control panel - then administrative tools - Then computer management - then go down to disk management - right click on the drive you are having problems with delete partitions then format and you got it
  • 903 Answers
You need to create a partition first, then format it.
Posted on Nov 28, 2008
Want to change a maxtor 3200 from windows format to apple mac
When you plug the drive, once mounted on the mac, go to applications>utilities>disk utilities then select the drive and choose partition. If you want the drive to be bootable you should then choose Mac OS Extended (journaled).
Cheers
Dec 03, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
Maxtor basic 1.5tb plugged in but wont run on pc
first you need to format it an need to creat a partition
go to computer mangement by right click on my computer then manage
go to disk mangement here u will find new hard disk create a new partiton and format it. if there is already a partition u need to give it a drive letter or need to activate it
Oct 02, 2009 | Maxtor BASICS Personal Storage 3200...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
My new maxtor unit will not booth up with my Mac. Do I need to download any software first?
i belive its formated as ntfs partition by default so you can not use it with mac directly
try this link and it will help you
http://macntfs-3g.blogspot.com/
Sep 29, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Want to format for pc
Since you want to format it, let's blow away the partition:
1. Right-click [My Computer]
2. [Manage]
3. Disk Management]
4. Find your Maxtor in the list or graph.
5. Once you are certain, then right-click the Maxtor entry (or graph) and select "Delete Partition"
6. Answer [Yes] to the next scary question.
7. If it has other partitions, you may want to examine them and delete them later.
8. You can now "New Partition" (right-click)
9. The create a "Primary" drive and format it.
*done*
Sep 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
PC see's Maxtor but I can not.
It is definitely possible you accidentally deleted the partition. If you already know how to open the drives properties sheet, do so, then click on the volumes tab and click the populate button. This will solve a few minor setup issues. If this doesn't work then it is likely that either the partition is gone/damaged. Try using disk management to look at the drive. If the partition shows up you may simply need to assign a drive letter. If it doesn't then chances are the partition is gone and will require assistance to recover.
Try these and let me know how you make out. If you have found that the partition is gone and need a pro comment back with your country/state/city and I will recommend one for you.
chris
Jun 06, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor access (pc and MAC)
Yes, formatting included erasing the drive and renewing the partition. If you want the drive legible on pc, but will be working in both environments, then you can do 1 of 2 things....
easiest, purchase MACDRIVE, it will allow a pc computer to see and use Mac items on the drive.
You could also transfer the content to another drive temporarily, format the drive in question to MS-DOS, then transfer all that content back over...using a MAC to do so.....
keep me posted..
Oct 28, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Need to format
Hi, You can try: 1. Open your "My Computer" and determine which of your HDs is the Maxtor III, say "E" or "F"; 2. Right click on the Maxtor III; 3. Click on "Format"; 4. On the File System, select FAT 32; 5. Click on "Start" Of course formatting your HD will delete its content. Alternately, you can: a. Open a command prompt window (type "cmd" in "Run"; b. type "format E: /fs:FAT32" assuming your PC assigned the drive letter "E" to the Maxtor III; c. hit "Enter" If for some reason this will not work, you may have to likewise delete the partition first. A handy 3rd party utility for the partition/format of a hard disk is Partition Magic. Hope this be of some help/idea. Post back how things turns out or should you need further information. Good luck and kind regards.
Oct 04, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
128 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
