Question about E-Machines T3085 PC Desktop
Locks up but usuallyshuts down
My t3085is driving me nuts.when i first purchased it it would lock up or shut down on occasion now it seems to lock up more frequently i just put in a new hard drive and got every thing loaded thinking it might be the hard drive also i purchas aviedo card gforce 7600 nothing has worked so far.i like it verry much the speed works for me so if there is a soulution i sure would like to get it fixed
Thanks Ken Slinker
  • Ken Slinker
    Ken Slinker Nov 29, 2008
    Sparky1500
    i did as you recommended put a 400 watt power,still have a problen. turned on t3085 i get nothing but the big E on the screen.tried to restore with disk but key board dosent work.
    THANKS Ken
    Genius:
  • 1,066 Answers
I would try getting a new power supply. since you got a new video card, you will need a higher powered one, like 350 to 450 watts
Posted on Nov 28, 2008
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
How to remove belts from 1994 dodge caravan 2.5 liter
Drive Belts
Print
INSPECTION
See Figures 1, 2, 3, 4 and 5
Check the condition and tension of all drive belts every 12,000 miles, or at least once a year. Loose drive belts can lead to poor engine cooling and diminished alternator, power steering pump, air conditioning compressor, or emission air pump output. A belt that is too tight places a strain on the bearings in the driven component.
Fig. Fig. 1: There are typically 3 types of accessory drive belts found on vehicles today
Fig. Fig. 2: An example of a healthy drive belt
Fig. Fig. 3: Deep cracks in this belt will cause flex, building up heat that will eventually lead to belt failure
Fig. Fig. 4: The cover of this belt is worn, exposing the critical reinforcing cords to excessive wear
Fig. Fig. 5: Installing too wide a belt can result in serious belt wear and/or breakage
Replace any drive belt that is glazed, worn, cracked, or stretched to the point where correct adjustment tension is impossible. If two belts are used to drive a component, always replace both belts when replacement is necessary. After installing a new belt, run the engine for ten minutes, shut OFF the engine and recheck the belt tension. Readjust if necessary.
ADJUSTMENT
See Figures 6, 7, 8, 9 and 10
Fig. Fig. 6: Engine belt tension chart-2.2L engines
Fig. Fig. 7: Engine belt tension chart-1987-89 2.5L engines
Fig. Fig. 8: Engine belt tension chart-2.6L engines
Fig. Fig. 9: Engine belt tension chart-1990-93 models
Fig. Fig. 10: Engine belt tension chart-1994-95 models
Two popular methods of checking drive belt adjustment are; the Belt Tension Gauge Method and the Belt Deflection Method. The former requires a special gauge and the latter requires a straight edge and scale or just a good eye for measurement. The deflection method will be used in the following belt replacement instructions. A rule of thumb for checking belt tension by the deflection method is to determine the midpoint between two pulleys of the drive belt and press down at that point with moderate thumb pressure. The belt should deflect to the measurement indicated in the following installation procedures. Adjustment is necessary if the belt is either too loose or too tight.
WARNING A belt adjustment which is either too loose or too tight will eventually damage the accessory that belt is driving. A too loose adjustment allows free-play in the belt which could transfer a whipping motion or shock to the accessory drive pulley. Similarly, a belt which is too tight will preload the accessory bearings, leading to early failure.
REMOVAL & INSTALLATION
See Figure 11
Raise the front of the vehicle, support on jackstands and remove the lower splash shield if access is hampered due to space limitations when changing drive belts.
Fig. Fig. 11: Support the vehicle, then remove the lower right side splash shield for access to the drive belts
2.2L Engines
A/C COMPRESSOR DRIVE BELT
See Figures 12, 13 and 14
Fig. Fig. 12: A/C compressor drive belt adjusting points-2.2L engines
Fig. Fig. 13: Loosening the locking screws for A/C compressor drive belt removal
Fig. Fig. 14: Removing the A/C compressor drive belt from under the vehicle
  1. Loosen the idler pulley bracket pivot screw and the locking screw.
  2. Remove the belt and install a replacement.
  3. Using a breaker bar and socket apply torque to the welded nut provided on the mounted bracket to obtain proper tension.
  4. Tighten the locking screw first, followed by pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR DRIVE BELT (CHRYSLER TYPE)
See Figures 15 and 16
Fig. Fig. 15: Alternator belt adjustment-2.2L engine
Fig. Fig. 16: Loosening the locking screw for alternator drive belt removal
If removal of the alternator belt is required, the A/C belt must first be removed.
  1. Loosen the pivot nut, locking screw, and the adjusting screw.
  3. Adjust to specification by tightening the adjusting screw.
  4. Tighten the locking screw to 25 ft. lbs. (34 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (41 Nm).
ALTERNATOR DRIVE BELT (BOSCH TYPE)
  1. Loosen the pivot nut, locking nut, and adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (34 Nm).
POWER STEERING BELT
If removal of the power steering belt is required, the A/C and alternator belts must first be removed.
  1. Loosen the locking screw, and pivot screw.
  3. Install a 1 / 2 in. breaker bar into the pump bracket slot, apply pressure with the breaker bar and adjust the belt to specification.
  4. Tighten the locking screw first, then the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
AIR PUMP DRIVE BELT
See Figure 17
Fig. Fig. 17: Air pump belt adjustment-2.2L engines
When servicing the air pump, use the square holes provided in the pulley to prevent camshaft rotation.
  1. Remove the nuts and bolts retaining the drive pulley cover.
  2. Remove the locking bolt and pivot bolt from the pump bracket, then remove the pump.
  3. Remove the belt and install a replacement.
  4. Position the pump, then install the locking bolt and pivot bolt finger-tight.
  5. Install a 1 / 2 in. breaker bar into the bracket assembly (block the drive pulley to prevent camshaft rotation), and adjust the belt to specification.
  6. Tighten locking bolt and pivot bolt to 25 ft. lbs. (35 Nm).
2.5L Engines
AIR CONDITIONING COMPRESSOR
See Figure 18
Fig. Fig. 18: Drive belt adjustment points-2.5L engines
  1. Loosen the idler bracket pivot screw and the locking screws to replace, or adjust belt.
  3. Adjust the belt to specification by applying torque to weld nut on the idler bracket.
  4. Tighten locking screw first, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR BELT
See Figure 18
If replacement of the alternator belt is required, the A/C drive belt must first be removed.
  3. Adjust the belt to specification by tightening the adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (35 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (40 Nm).
POWER STEERING PUMP
See Figure 18
If replacement of the power steering belt is required, the A/C and alternator belts must first be remove.
  1. Loosen the locking screw and pivot screw to replace, or adjust the belt.
  3. Using a 1 / 2 in. breaker bar positioned in adjusting bracket slot, adjust the belt to specification.
  4. Tighten the locking screw followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
2.6L Engines
ALTERNATOR/AIR CONDITIONING COMPRESSOR BELT
See Figure 19
Fig. Fig. 19: Drive belt adjustment points-2.6L engines
  1. Loosen the locking screw, jam nut, and pivot nut.
  2. Loosen the adjusting screw.
  4. Adjust the belt to specification by tightening the adjusting screw.
  5. Tighten the locking screw followed by the pivot nut. Tighten to 16 ft. lbs. (22 Nm).
  6. Tighten the jam nut to 21 ft. lbs. (28 Nm).
POWER STEERING PUMP BELT
See Figure 19
If replacement of the power steering belt is required, the alternator and A/C belt must first be remove.
  1. Loosen the pivot screw, and the locking screw.
  2. Remove the timing pickup.
  4. Install a 1 / 2 in. breaker bar in the adjusting bracket slot, torque to specification.
  5. Tighten the locking screw, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
  6. Install the timing pick-up, and tighten to 160 inch lbs. (18 Nm).
Jul 26, 2012 | 1994 Dodge Grand Caravan
How do you adjust the rear wheel bearing?
Rear wheel bearings on front wheel drive vans are much like front wheel bearings before front wheel drive.
You have an inner and outer bearing with a nut and lock washer.
After the bearings are packed with grease, you tighten down the axle nut until snug then back it off a notch. Then put the lock washer or lock ring on. Some have a cotter pin to hold the nut in place.
The wheel should spin with no drag from the bearings.
Jul 07, 2012 | 1993 Plymouth Voyager
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Apr 25, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
In 4 wheel drive the front makes a knocking noise and feels like it is slipping. This occurs when it is going up a small grade but seems fine when I am on a flat road.
VERY popular situation to all S-10s. You'll need to purchase and install or have installed, a 4x4 locking kit. This consists of all the necessary nuts, washers, and the vacuum valve assy. This should be purchased from the dealer to avoid a bunch of headaches. Thanks, Dana
Oct 02, 2009 | 2001 Chevrolet S-10
Wheel locks up when tightened down.
hummm the nut should be at 100nm which is a bit really when you tighten it a tad does the wheel move side to side or feels rough get back to me
Sep 26, 2009 | 2004 Suzuki GSF 1200 Bandit S
Rear wheel won't turn when pedaling
hi there,
put your bicyles on upside down position,wheel should on top so you can work freelywork on ,then rotate the pedal to check what the problem it should be freely rotating,check break pads if it was engage even w/o pressing control.release brake cable wire to loosen.if not in the break,check the sprocket gear if connecting to the chain belt,check your sprocket release lock,if damage replace sprocket, check the bearing of the two wheel center shafting if worn out replace bearing,on front wheel there are two quick release nuts,loosen and pull out wheel and loosen all nuts and lock plate bearing,pull out shafting with the bearing,examine mostly bearing worn out also shafting in some occasion its worn out also,possible if you want replace one set center shafting and bearing ts not costly,on rear wheel with sprocket it different to disconnect,beacause there is sprocket,you should dismantle the locked plate and lock nuts of sprocket before the shafting assymble same procedure now on front wheel when after disconnecting sprocket on rear wheel.hope this will guide you and solved your problem have anice day.
Jul 14, 2009 | Mongoose Cycling
Fuel shutting down
Anti theft system. You might have a door lock causing the anti theft system to kick in. (thinking its being stolen.)
May 18, 2009 | 1999 Chrysler 300M
E-Machines T3085 PC Desktop Logo
110 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
