posted by Sylvester on Jan 13, 2007
My 46" Daewoo Plasma TV took a lick from a grandson and the screen cracked all about. Is this just regular glass that I could replace myself or is it some exotic blend of materials that would require a call to Daewoo or possibly a trip home for the daewoo, or is this a lights out situation?
Any and all advice is appreciated
Thanks
Milton
Comment by Sylvester, posted on Jan 14, 2007
Think I will take Pauls advice and chalk it up.
By the way I have 46 daewoo plasma tv with broke screen for sale! Thanks Paul for saving me a lot of time and money.
Milton
www.thepropstop.com
Milton
www.thepropstop.com
1 Other User Has The Same Problem
Comment by wackson, posted on Jun 13, 2008
i bought a phillips plasma tv, and it fell off the wall the glass is shatterd all on the inside, i was wondering if it was fixable, as it cost me alot of money.thankyou.
Best Solution
posted on Jan 13, 2007
Your are probably pooched, and repairing this would be expensive.
Plasma display panels are constructed as a pair of glass panels spaced about 0.1 mm apart, with an excitable gas in the gap between the two sheets, It's like have millions of teeny tiny florescent lamps all packed together. see http://electronics.howstuffworks.com/pla... for a better explanation then I could provide here.
WARNING: There are high voltages present in Plasma sets, and they should only be serviced by trained technicians.
Now, many sets have a protective glass sheet over the actual plasma display.
If the display is still working 100%, but the outermost glass is cracked, it may be possible to disassemble the set, remove the protective glass and either live without it, or have new glass cut to replace the damaged protective glass.
Good luck.
Paul.
Good luck.
Paul.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 04, 2008
I had the same problem as you. My 1 year old killed my LCD. I picked up a screen protector from
TV Armor. http://www.tv-armor.com Now I dont worry about him breaking it again. I checked out the one from thescreenprotector. Its kinda expensive. The one from TV armor was cheaper and thicker.
Eric
Eric
Solution #4
posted on Jan 31, 2008
I toohave a 46 in daewoo that has a good screen, what model is yours???Call me i need a part out of your television
865-936-1954
865-936-1954
Suggest a new solution for this problem
Post a New problem for Daewoo DSP4210GM 42 in. Plasma
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Daewoo DSP4210GM 42 in. Plasma Television
Fuzzy picture - lines moving...
I am getting really bad picture... Answer This...
46" plasma daewoo
46" plasma daewoo
Hi, Could someone please help... Answer This...
daewoo 42 inch plasma tv
i have loads of pixel lines on... Answer This...
plasma tv 44 inch daewoo
picture has gone pink on me... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
