Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F&P DD603i Greetings! My mother-in-law went to use her 18-month old Fisher&Paykel DD603 bottom drawer today (Thanksgiving) but it started beeping and showed an error with the motor. From the messages here, it looks like you may have a service manual for this unit? If you do, would you be kind enough to forward it to me also? My mom-in-law would greatly appreciate it, and I could probably get an extra slice of pumpkin pie!! Thanks, Craig teamhickson@yahoo.com
  • 145 Answers
Service manuals can be found at http://www.fisherpaykelparts.net
Posted on Dec 11, 2008
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
185 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
