Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Wasp inside Hitachi 50" rear proj. tv
Can you tell me how to remove the screen safely?
  • Hitachi Master
  • 5,138 Answers
Pull bottom cover off front you will see screws holding screen on remove all of them then slide screen upwards and OFF.
Posted on Jan 01, 2009
Hitachi 50 inch plasma - no sound, no picture, red light on start up in the lamp and temp indicators on the front of the TV.
If it has lamp and temp sensors it is not a Plasma---locate and remove the lamp and look to see if it is shattered inside--owner manual will tell how to remove--its behind a door on right side or rear of set in most cases.
May 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Can am Hitachi 50GX49B rear Projection TV be diassembled to move it to an area where narrow stairs prevent the complete unit to be mover through this area? I have noticed that inside there are 3 screws on...
Removing the screen is your best bet -
1 Remove speaker grill
2 remove 4 screws holding the screen frame
3 then lossen the bottom corners where the screen meets the frame by pulling outward (some force is required) and work your way upwards towards the top (two people may be required for support)
4 tilt the loosened frame(20-30degrees) from the bottom up and the top shoul lift and seperate from the frame.
After the screen is of you'll be able to tell what to remove next.
Good Luck!
Sep 21, 2009 | Hitachi 50GX49B 50" Rear Projection...
Where Can I Buy A Replacement Screen For Hitachi 51f59a Rear Proj
Hi, I have a brand new in the box screen for a 50 inch rear projection tv. I was going to put it on ebay but if this is what you need and what I have--well we can go from there. Email me with any questions you may have. Thanks, wrapper494@msn.com
Mar 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Need to move a 57 inch hitachi rear screen proj TV
No, do not attempt this as you will damage the unit if you try to take it apart and reassemble it. They are not built for dis-assembly and re-assembly. They are easily damaged. Rather, rent a large industrial hand truck and use several straps to secure it to the hand truck and about three men to help you. It is about the only way to do it.
Be careful... there is a fragile mirror inside which can be broken if bumped abruptly.
Jan 26, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Open Questions:
Televison & Video Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
