Question about Equator EZ 3600 CEE Front Load Washer / Dryer
A lot of water remains in machine at end of wash cycle
Equator ez 3600 washer dryer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
The drain pump might have gone bad, check if the drain pump is making some kind of noise and also check if the drain pump is not obstructed.
You can open the coin trap on he right hand side bottom of the unit and clean the same for any blockage.
Posted on Feb 26, 2010
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
Sep 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
Where can I buy a new belt to my equator EZ 3600 C / B ?
You can purchase a new belt for your EZ3600C from appliance desk through their website www.appliancedesk.com and then click on shop parts.
Sep 26, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Won't let in cold water. set on delicate, it used
remove cold water supply hose, if all is well and screens are clear , means cold water valve is faulty
Jul 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Leaks near filter
It may be the drain pump that is leaking, you can open the back panel of the unit and figure out if it is so by checking the drain pump for leakage just when the pump starts to work.
Oct 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Door
if it is after the wash cycle, it is normal to take a few minutes before the door will open. if it is after a dry cyle, there is a problem with the door mechanics
Nov 15, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
227 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
