Question about Samsung RS2630WW Side by Side Refrigerator
Samsung side by side srs580dw stops freezing and chilling
Our fridge has done this same thing twice now. It runs fine for a few weeks and then all of a sudden the freezer and fridge stop working. We can still here motors and fans running and the indicators or the front work although the temp will not show that it is going up it stays at the temp it was whe when it quit, ie -20 and 3. Then all of a sudden three days later it starts up again for no reason. What can we do to resolve this please!
  • linda falkingham Jan 14, 2007
    I see that this is a maytag schematic, does that mean that saumsung is made by them? Also, is this a part that we could put in ourselves? All of a sudden this morning the fridge is at -13 and 0 degrees and is feeling cold but the freezer isn't getting any colder than that.
    Thanks again, it seems to us that we are finally on the right track now after having gotten and repair bill for 300 for putting in new sensors.
    cheers!
  • 237 Answers
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Posted on Jan 14, 2007
  • Marc Wilson
    Marc Wilson Jan 24, 2007
    Yup, the different companies use other companies to make their products. Like Kenmore is not really Kenmore, it can be Amana, GE, Maytag, etc. Ya never know till you order parts and see what brand the OEM part is.
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Freezer side is frozen, but refrigerated section is not cold
This happens when the coils frost over. That stops airflow from freezer to refrigerator. If the fan in the freezer is running read on: All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. Give the shaft a slow twist until a click is heard. The compressor should stop. Check the fridge in 1/2 hour to if it restarted. Sometimes the nudge will make the timer run for a while. (be sure to make it restart if it does not on it's own)If I'm on the mark you will need to get a replacement timer. The process can be repeated daily until you get a replacement.
Hope this helps.
May 26, 2009 | Kenmore Refrigerators
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Nov 06, 2008 | Samsung RS2630WW Side by Side Refrigerator
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
SAMSUNG RS21DCNS
The middle part of my refrigrator (RS21DCNS) is full of ice. i have removed ice many times. could you tell me whats the reason and solution of this?
Jan 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
288 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
