Question about Vtech Cordless 6041 Phone
Key pad locked
It seems that the key pad on my phone is locked,if a key pad can be locked.the screen works,when i paged the phone it rang.just will not work when you press any botton.it really did work this morning
  • tylersharp51 Dec 24, 2008
    My key pad is locked.
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
The range is locked and holding down the lock key for 5 sec doesn't work.
you would have to hold the stop/clear/lock key key for 10 seconds not 5 and if this doesnt work then you would have to replace the touch pad or clock most likely but before replacing pad check to assure that connections are all conected properly please message back if you have any more questions thanks again some technicians will use a small wire to manually open the door by hooking it on the lock arm and pulling to the left
Aug 15, 2010 | KitchenAid Kitchen Ranges
Keys not functional though you can only switch the phone on
May be the phone is 'locked'. Check for a locked sign (probably a padlock sign) in the top edge of the screen.
Jul 13, 2009 | Nokia 6500 Slide Cellular Phone
Accidentally locked handset KX-TCD510
try code 1000, that seems to be standard lock code pre-set for the phones, else take battery out for about 10 minutes or so ( this will likely erase your info, but you cannot get to it anyway). good luck!
Feb 08, 2009 | Panasonic KX-TG1033S Cordless Phone
Iphone has a problem
Hi Bob. If your touch screen is fully functional on other areas or pages, I would restore the firmware. Should take care of that prob. If it is not responding at all, then you would probably be looking at replacing your digitizer.
Jan 29, 2009 | Apple iPhone Smartphone
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Vtech Cordless 6041 Phone Logo
20 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
