Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door goes back up unless button on remote is held depressed
If I press the remote, the door will not go down. I have to hold the button down until the door is completely closed, or the door will go back up.
  • vinosand Nov 29, 2008
    same...must hold button down to completely close. sometimes tempermental when reaches bottom and goes back up again.
    car remotes work to open but not to close. would like to fix it quickly...winters here.
I read the GDO manual.
Thanks
Posted on Nov 30, 2008
Had excat same problem. In our case it was that the two sensors on either side of the door were slightly misaligned. The greed LED on the one sensor was solid green; the LED on the other was flashing. I moved the sensor with the flashing oight around until it showed a solid green LED. When i pushed the wall button it wokred perfectly. Our doors are about 15 years old and the sensores were very loose. Once you agn them, tighten the wing nuts and check them periodically.
Posted on May 02, 2009
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
How to program 2005 toyota sequoia garage door opener?
Hello.I will be glad to help you out.
Choose which of the 3 buttons you wish to use, on the car.
Take the remote transmitter, depress the actuator button, and continue to hold it until advised to release.
Depress the button, on the car, of your choice, and hold it down until advised to release.
Hold the garage door actuator (while holding the actuator button down) above the car's 3 buttons.
Rotate the door transmitter until the red light above the 3 buttons starts to flash slowly.
Stop moving the remote around when the light flashes slow.
Within several seconds, the same light n the car will now flash rapidly.
Release the car's button, release the transmitter button.
Verify that the door now operates..
Nov 29, 2009 | 2006 Toyota Sequoia
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER IN MY 2005 LEXUS LS430
THE DEALER PROGRAM THE REMOTE OR DOWNLODE THE AUTO MANUAL.
BOOKS4CARS.COM
Apr 02, 2009 | 2005 Lexus Ls 430
Remote unit of garage door not able to close garage door
Does the safety feature react when blocked?  If not, the problem may not be with the remote.
The low force switches used in most remotes are very simple devices and fairly reliable but they can fail over time. They are one of two common types; one is a carbon button molded to a silicone sheet with one or more buttons attached and with the user side marked and protruding through holes in the case. The button contacts a circular area on a printed circuit board that once was flashed with a thin gold plating that never corroded. In more recent times, they have dispensed with the gold and you now have the tin plating of the circuit board only and this tends to lose its conductivity with time. These can often be restored by exposing the printed circuit board and using a standard pencil eraser to gently scrub the contact area. Because of some waxy component of the eraser, it is wise to clean the contact pad with a cotton swab and some alcohol before closing up the case.
The other type of 'soft touch' switch uses a thin, dome-shaped metal contact that is depressed to make contact. These don't suffer from contaminants as much as fatigue and may not want to 'pop' back after being depressed. This type may or may not be restorable depending on how they are held in position.
Finally, if you have a 'police' scanner, you might be able to use it to detect whether your remote is putting out any signal at all by allowing the scanner to scan up to ~500 MHz since most of the RF remotes use frequencies below this point. With the scanner scanning, you would just hold down a working button of the remote until the scanner stops on that frquency then, overlapping, press the non-working button to see if the scanner finds it again. If not, the remote is at fault. If the scanner finds the signal with all buttons, then the receiver is at fault and without some technical skills and equipment, there isn't much you can do at home.
Mar 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
How do you program the garage door remote?
Turn the key to the "ON" position; do not start the vehicle.
Press on the button of the 3 available to you on the vehicle and hold it until advised to release it.
Take your garage door remote transmitter, and press the button that you use to make the garage door operate, hold it down until advised to release.
With the vehicle button being depressed, and the remote button depressed, hold the remote up against the area where the 3 buttons are located. It needs to touch the area wher the buttons are.
Keep moving the remote around slowly, back & forth, spin the remote, until the red light starts to blink slow.
After the light begins to blink slow, hold the remote in that exact position until the lamp blinks real fast.
Relase both buttons.
Repeat for a second remote on another button.
Jun 29, 2008 | 2001 Toyota Sequoia
Resetting bulb tyla1000
Most modes can be reset by holding the volume down button on the tv until the volume is all the way down. Continue to hold the volume down button on the tv and while depressing the volume down button on the tv press and hold the pip button on the remote until the reset message appears on the screen. Some models are different and while depressing the volume down button on tv press and hold the split key on the remote. Most times these instruction come inside the lamp box you purchased.
Mar 28, 2008 | Televison & Video
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
281 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
