Question about Samsung 80092 Microwave Oven
Microwave oven making popping noises
Tried to cook noodles but the oven made exploding noises.shut it and wondering what could have caused it.please help
  • jmpolly Jan 06, 2009
    GE over the range microwave
    model # jnm1851dmbb
    Is it easier way to remove the cover?
  • Samsung Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please write back with your brand and model number if you need further help.
Posted on Dec 02, 2008
Cooking with metal probe not fully inserted into ham Frigidaaire Gallery Series Micro....noises occurred ...popping sound....and microwave shuts visual evidence on buttons or surface ...can it be...
Unfortunately when the metal probe was inserted in the ham it caused the magnetron to arc to the probe causing it to short out, but usually the thermal fuse will open and shut the system down preventing damage. It usually takes 30 to 60 minutes for the fuse to reset and allow the microwave to run, try heating water! if you are lucky the oven is unharmed. But if there no change the magnetron will need to be replaced which probably would not be cost effective, cheaper to buy new unit.
Mar 07, 2011 | Frigidaire Microwave Ovens
GE microwave model number JVM230WV 001 popped while cooking now when turned on it will only make a humming noise. Light comes on but no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
At least twice in the past month have had food explode all over the microwave (as if it was overheating). Items vented properly or not covered at all. this time, kept making poppong noises for at lesat 10...
If you have an item overheating, try looking at the directions on the unit for the watts and adjust cooking time according to the oven. Some foods will explode if left for too long in a quick heating microwave oven. If this is a new problem and the microwave is 4 years old, you may consider the unit is beyond its useful life. Its difficult to tell w/o knowing the brand, but it could be the meagtron tube is simply wearing/worn out. Let me know if this helps. m
Oct 20, 2009 | Sharp R-428J 1200 Watts Microwave Oven
My microwave oven shuts down when set at high a high cooking number. I must wait a while before it can used again. I have a GE spacemaker
It may be that your magnetron is overheating, which will trip the magnetron's thermostat, which will interrupt power until it cools down a few minutes later.
Or it may be a defective magnetron causing electrical interference that disrupts the control circuit.
In order to help you, we need your full model number and some further information.
So please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
- How long does it cook before it shuts down?
- When it shuts down, does it go completely dead, or does it just stop with the display still lit?
- When you try to cook, do the inside light, turntable, and internal cooling fan all come on?
- Is it making any unusual noise?
- Is it louder or quieter than usual?
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
May 30, 2009 | GE JES1358 Microwave Oven
Microwave won't heat anymore
May 24, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
Exploded a musical mug in spacemaker xl1800 microwave.
If there's no damage it should be fine.
I would double-check for cracks, especially in the inner door glass and the screen / mesh.
If it looks fine, heat a cup of water in a microwave-safe container for about 2 minutes and see if it cooks without arcing or odd noises and that it boils in about 2 minutes.
As always, never leave a microwave unattended while running.
Jan 28, 2009 | GE XL1800 1100 Watts Microwave Oven
GE xl1800 spacesaver microwave
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Feb 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung 80092 Microwave Oven Logo
73 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
