Question about Smeg Kitchen Ranges
Hi the minimum flame on my cooktop is too high - I need to adjust this - the instructions suggest there is a screw within or at the side of the shaft beneath the control knobs - this is not true - model is PGFA95FX. Thanks Alan
    Sergeant:
    Champion:
  • 311 Answers
Don't know the brand from that#, but Adj screw is typically inside the shaft. Need a long very thin screwdriver to get to it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Want to adjust the knob to make the flame smaller than @ current setting??
pull of the knob
put a smill flashlight down the selector shaft
you should see a small adjustment screw
probably a tiny flat head
very small turns
start from the lowest setting if you start from the highest you could loose your low flame below the grid
always adjust fromt the lower settings
some of these units are factory set and cannot be adjusted by the consumer,,,,unless you want to install new adjustable gas valvews
Oct 27, 2009 | Dacor Preference SGM365SS Gas Cooktop
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
KitchenAid Stovetop with grill and griddle - KGCP484KSS0
hi im gerbee, try to clean the sensor valve by using a scott brite, the sensor place in the side wen the flame is on like a gold metal, 2nd try to adjust the flame control by using a plat or + screw,u see it at the gas control knot on top the small screw.adjust to high flame is touch the sensor valve.sory for my english.tnx gerbee i hope i help u
Nov 30, 2008 | KitchenAid Architect KGCP484KSS Gas...
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Pilot Flame is too high.
You will only need to purge air from the supply if this is newly installed or if you have recently disconnected / reconnected the main gas supply for some reason. Otherwise, you can just skip that step.
If you do need to purge the system do the following:
MAKE SURE THE ROOM IS WELL VENTED TO OUTSIDE
REMOVE ALL SOURCES OF POSSIBLE IGNITION
Fully open the largest burner and allow to run until gas is smelt.
There is no way to say exactly how long it needs to be open as this very much depends on the length of pipework feeding the appliance, but in a typical domestic installation, this shouldn't be more than about 5-10 seconds.
Hope this helps,
Matt
Mar 03, 2008 | Maytag MGC5430 Gas Cooktop
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
Kitchen Ranges Logo
130 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
