Question about Brother MFC 210C All-In-One InkJet Printer
Can't print I am out of cyan ink but just want to print with black but no can't do nothing. please help me Thank you
    Problem Solver:
  • 7 Answers
Ok, if your brother has four cartridges then I'll assume you have black ink available. There should be a printer setting to print in black only, especially if your trying to print a colored document. If your brother only has three cartridges then cyan is necessary to form black; you will have to buy a replacement cartridge.
Posted on Nov 28, 2008
My brother CIP-J140W is only printing in cyan. I had accidentally put the cyan cartridge in the black cartridge spcae. Despite changing them around, cleanre the head etc, it is still only printing in cyan....
Oops, You really have to print, selected black, till all Cyan ink is gone. This could take a while. Cleaning the head, won't solve anything.
If you really want to clean the ink out of the head and everything, you need special cleaning fluid. Refill shops do have this fluid. You should bring some cleaning fluid in the tube under the black cartridge, in the tube where the ink is going in. If you have a syringe you could try to gently press some fluid through the tube. Not to strong. could damage the head.
After placing back the black cartridge, select clean the head and let the printer do some black and withe print jobs, till the cyan is gone.
Nov 27, 2013 | Brother MultiFunction Center MFC-440CN...
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
Hi I removed the black print head and cyan, but since my SP-540V no longer prints black and cyan, the ink inlet pipes are empty. I think the cirduit is defused. how to reboot the ink circuit. Thank you....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 09, 2011 | Office Equipment & Supplies
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I cannot get my printer to print. I have black ink and all other colours except cyan. I want to print in black and white but it won't work, please help
Hi there!
In order for you to print you need to refill your cyan ink cartridge. Even if you just want to print black and white.
May 08, 2011 | Office Equipment & Supplies
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Ink in blue slot is not dissolving
If your printer still can print but with no cyan color then you most likely have a bad printhed. If your cyan ink is not melting it's because it is not using any ink . Get into the "print quality" menu and print the test page. If you get black, yellow, and magenta but little or no cyan then your printhead is bad. Whith these machines cyan is the first color to have poblems starting with weak or missing jets.
You can try to run the "eliminate light stripes" to see if it will help.
Run it about 3 to 5 times. If still not working right, turn the printer off for at least 4 hours and then test again.
Hope this helps,
Dan
Oct 28, 2008 | Xerox Phaser 8500/DN Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
