Question about Plumbing
KitchenFaucet - high picthced noise when hot water runs
Faucet is a Moen Single arm with spray head & normal water run all in one piece. When we turn faucet on water runs OK, no noise. However, when turned to hot & water reaches hot water temp level a highed sound is made by the faucet. Faucet is less than 1 yr. old.
  • 2 more comments
  • Anonymous Apr 02, 2009
    single handle kitchen faucet with spray line.. whenever water is turned on, it has a loud shreiking sound which can drive a normal peron insane..do I have to change some filter ?? what can do this all of a sudden..please help me as my husband recently passed due to prostate problems and I am scared and clueless...
  • Anonymous May 18, 2009
    I've replaced the entire cartridge with no help. Two other installations at friends house also makes same noise when water pressure cycles to low from well.
  • Chas Covey
    Chas Covey Nov 05, 2013
    Singe handle Phister faucet with spray line...humming noise when hot water turned on. Does not occur when cold water on. Solution was faulty sprayer head. Called company support, which analyzed the problem, and is sending a replacement sprayer head.
  • Anonymous Mar 23, 2014
    cannot turn the faucet off and it continues to run. Have to turn the water off.
  • 3 Answers
The hot water is expanding a little rubber o-ring and its allowing air to wistle through because it is not sealing right. Replace the rubber washer or o-ring that is on the hot side.
Posted on Nov 27, 2008
  • Chas Covey
    Is this rubber o-ring on the faucet or the shut off valve?
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Apr 21, 2012 | Moen Plumbing
When I press the button on the spray handle, water flows through both spigot and spray. Moen model 7310.
You have a piece of sediment lodged in the spray head which can be removed by dissasembling the head... could also be a bad rubber seal in the head which might require replacement.
Nov 29, 2010 | Moen 7310 Legend Single-Handle Kitchen...
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Bathtub single handle faucet had not been used for a few months. Now when you rotate to hot water posiiton, there is no flow. Cold is normal. Hot water works fine at nearby sink & otherwise. Did an...
yes, and hopefully piece's of the cartridge's rubber have not come off and lodged in the water port's.have had this problem quite a few time's.remove your cart' and while it's out, run water to flush out the valve body.shine some light in body before re-assembly.
Dec 23, 2009 | Moen & One Handle Tub & Shower Faucet
I have a single handle Moen kitchenfaucet. I
You turned the faucet body when you tightened faucet you need to loosen and reposition body so handle goes left and right equally and retighten while making sure faucet body does not move
Nov 12, 2009 | Moen Plumbing
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Hot water on cold side when first turned on moen 7600 series
did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Plumbing Logo
282 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
