Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
No water will dispense at door
Ice cubes & crushed ice OK & 12 hrs. ago water dispenser was working. Company shows up for Thanksgiving & no water?
  • 2 more comments
  • Anonymous Jan 18, 2009
    no water will dispense and no ice will come out. Ice maker works. water will occasionally work. Have changed filter and still not working.
  • Anonymous Jan 27, 2009
    ice dispenser works but no water is dispensed
  • mrtaxpayerch Mar 10, 2009
    The defrosting "heater " was found to burned out. Tech replaced the unit & all is well. If your freezer is icing up on the back wall of the compartment you may need to call the Tech
  • ehday Mar 20, 2009
    no ice in ice maker-----water ok
Had the same problem, water line freezes on refrigerator side. Usualyy when my husband tries to chill the beers in the turbo cool a few too many times. Unplug unit, until it thaws. easy.
Posted on Mar 10, 2009
Don't know, problem solved itself
Posted on Nov 28, 2008
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Not dispensing ice cubes, only crushed
Yup, do like I did. Clean the caddie of all ice cubes. Place a large water catching tray under the door, and run hot water from the inside where the the caddie holds the ice. You will see large chunks of ice that was freezing up your cube maker. After a couple of glasses of hot water pouring through the caddie, it will defrost and the frozen part will be released. Take off the caddie, and run water through it from your sink. Clearing all ice debris. Replace the caddie. Do not use for 24 hours, and it should run beautifully. Mine did that before it froze up and I cleaned it. You should probably take the caddie off every couple of months and run water through it to keep it clean of frozen debris, make sure its dried off well and put it back, wait overnight. and it should be ok.
This is what I did, hope it helps.
May 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
263 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
