Question about Acer Aspire 3623WXMi Notebook
Acer aspire 3620 lid broke and screen needs to be replaced
Tech attempted to replace screen and stripped screws and now the lid is floppy on the hinges and misaligned. Can a new lid with a good screen be purchased and replaced without a hinge issue?
    Scholar:
  • 94 Answers
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
Posted on Nov 27, 2008
Aspire 5251-1513 ac adapter broke
Don't do that if you are not good for repairing laptop. That will damage your laptop and be dangerous.
Either repair your laptop adapter or buy a new adapter. If you can't let your laptop charger repaired by yourself, you had better replace a new charger.If you are on a budget on a new charger, consider buying a third party charger:Intocircuit Acer Aspire 5251 AC Adapter 65Watt 19V 3.42A
Sep 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Anyone replace the inverter on an Acer Aspire 6920?
I haven't replaced an inverter on this model before, but have done on a few other makes.
Generally the inverter is located on the bottom edge of the LCD screen behind the bezel.
The bezel is secured with screws on the front and or the edges of the bezel. these screws in most cases are hidden by small round plastic covers, they need to be carefully peeled off to reveal the screws. Also the bezel is held in place with plastic clips and double sided tape. Slip a thin metal strip between the screen and the bezel and carefully pop the bezel off, start at the bottom edge and work along each edge to release the bezel. Be careful not to scratch the LCD screen and be careful not to apply pressure to the face of the LCD screen otherwise you will crack the LCD screen.
Aug 12, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer 9402WSMi laptop with a broken lid.
You may not need to replace the lid just the hinge.
Try this WEB site for Acer parts.
Use this link :-
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Jun 30, 2009 | Acer Aspire 9402WSMi Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Acer Aspire 3620 laptop screen is coming off and goes black
sounds like a hardware problem....if u know how to assemble the laptop.it will be easy for u to fix that problem....all that things are connected to the mainboard..re insert all the cables what is loosen...regarding the headphone jack,if you have an extra jack you can replace that by resolder.
Jan 01, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer asoure 3620 lid broke and screen needs to be replaced
Buy the screen here, great prices and good customer service:
http://www.smartmicrousa.com/
Back cover with brackets here:
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2177
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Need to open acer aspire 3620 to replace fan
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
Thanks, Joe
Oct 16, 2008 | Acer Computers & Internet
Component missing Acer aspire 3620
Hey,
The vga board on this laptop heats up very easyly and the heatsink is uselessly small. Video may fail withing 12 months. I would recommend another laptop model, this series 3xxx and 15xx have cooling issues and parts fail often. Not much you can do about the problem.
Thanks,
Ekse
Aug 19, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3623WXMi Notebook Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
