Question about Acer Aspire 3623WXMi Notebook
Acer asoure 3620 lid broke and screen needs to be replaced
Tech tried to open to replace screen and stripped screws and now lid is floppy and misaligned. Can i buy a new lid and screen and repair both situations?
  • Acer Master
  • 4,338 Answers
Buy the screen here, great prices and good customer service:
http://www.smartmicrousa.com/
Back cover with brackets here:
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2177
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
I have a Kenmore washer that locks automatically through entire wash from start to finish. I was locking and stopping so I forced it open and broke the lock. It also broke the hole thing part but I don't...
You need a set of "star keys" you can buy them at a auto parts store. I can't see the model number otherwise I could get you the part number for your lid lock. It is suppose to lock start to finish as you described it was doing. I'm a tech so can get you part number but only with a model number
Feb 19, 2015 | Kenmore Washing Machines
How can I switch out my hp 17in lid?
The front is called the bazel, the screws are hidden behind small round rubber cups, some are dome shape and others are flat, carefully remove them with a fine flat head screwdriver in the order that they are removed. Some laptops may have screws on the side, remember to put one finger under so the screen does not get scratched.
May 26, 2012 | Computers & Internet
Left hinge is broke and stripped of the screw cannot open or close laptop
hp has a known issue with laptop hinges and they also have a recall on the same.just call up hp tech support and check if your notebook falls under the recall.if it does they will replace it for free.
Jan 12, 2010 | HP Compaq nc6230 Notebook
Acer 9402WSMi laptop with a broken lid.
You may not need to replace the lid just the hinge.
Try this WEB site for Acer parts.
Use this link :-
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Jun 30, 2009 | Acer Aspire 9402WSMi Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Acer Aspire 3620 laptop screen is coming off and goes black
sounds like a hardware problem....if u know how to assemble the laptop.it will be easy for u to fix that problem....all that things are connected to the mainboard..re insert all the cables what is loosen...regarding the headphone jack,if you have an extra jack you can replace that by resolder.
Jan 01, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer aspire 3620 lid broke and screen needs to be replaced
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Need to open acer aspire 3620 to replace fan
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
Thanks, Joe
Oct 16, 2008 | Acer Computers & Internet
Acer Aspire 3623WXMi Notebook Logo
185 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
