Question about Sanyo DVW-7200 DVD/VCR
Progressive scan how do i get the progressive scan to shut off
Press and hold the play button down for 5 seconds, this will turn the progressive scan feature off. As per the troubleshooting manual.
Posted on Sep 15, 2007
When i try using prgressive scan it comes up error why and how can i get progressive scan to work
In order to use progressive scan you must have a progressive scan compatible tv. Check your users manual to find out if its compatible. If it is it should give instructions to turn on the progressive scan option for tv.
Aug 26, 2011 | Zenith XBV442 DVD Player/VCR
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
We have a Koss home theater A/V system with progressive scan DVD player. when I tried to open the dvd it gave us a msg 4, and then the system shuts down, then we have no sound nor can we load a dvd. We...
We have a Koss home theater A/V system with progressive scan DVD player. when I tried to open the dvd it gave us a msg 4, and then the system shuts down, then we have no sound nor can we load a dvd. We have tried and tried to find out what msg 4 is we have checked the manual, nothing, would appreciate your help. Thanks
Jun 22, 2011 | Audio Players & Recorders
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
Does the JVC xv s40 have progressive scan?
Sorry but this DVD does not have progressive scan. Before buying another DVD player with progressive scan ensure the tv you have can receive progressive scan signals. If not it doesn't matter if the dvd has progressive scan or not. Hope this helps.
Mar 08, 2010 | JVC XV-S40 DVD Player
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Progressive scan
To turn off Progressive Scan, press and hold the DVD Play button for 5 secs until the Progressive Scan indicator light goes off.
Jul 28, 2008 | Sanyo DVW-7200 DVD/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Televison & Video Logo
126 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
