Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher leaks when jet dry rinse is added everytime.
Every time I add the rinse agent to my dishwasher it leaks, this is the
only time it leaks, but it is getting very annoying because most of my
dishes usually look like **** because I am sick of it leaking and I don't
put the rinse agent in when it is always needed.
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
"add rinse agent" indicator light will not reset?
Switch the unit from mains to reset and try again
Jul 25, 2014 | Bosch Dishwashers
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Machine wont empty properly pump seems to work. machine sounds like its operating normally bosch classixx dishwasher
dont use soap with jet dry or rinse aid in it. use regular cascade soap and fill completely with jet dry rinse agent. your unit is over sudzing .if this is helpfulto you send me a 4thumbs up post
Feb 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
The inside of my stainless steel dishwasher looks as if it has a white film on it. My glasses are also looking like they are etched. I haven't changed the dishwasher soap...any ideas what is causing...
are you using a rinse agent such as jet dry( you should be) and if your using tabs with rinse aid built in dont add extra rinse aid to dispensor, . water temp might be an issueperhaps some detergent has gotten into the rinse aid compartment mistakenly
Nov 04, 2008 | Dishwashers
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
840 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
