Question about Epson Stylus Photo R320 InkJet Printer
R320 PRINTER CANNOT CLEAN HEAD
KEEP DOING HEAD CLEANER BUT CANNOT GET THEM ALL TO CLEAN
I have been advised by epson before to clean no more than 3 times in a row and failing that, dont clean again untill the next day. This actually worked for me last time we had major head cleaning issues
Posted on Feb 11, 2009
  • 28 Answers
Manualy clean it using cotton and alcohol
Posted on Nov 28, 2008
When at steady speed then picks up and goes good like it gets a burst of fuel fad runs right but then it will keep doing it
Clean the inside of the throttle body with throttle body cleaner and a clean lint free cloth. Check or have checked the TPS Throttle Position Sensor as it can cause idle and stumble issues.
Mar 19, 2015 | 2004 Nissan XTerra
NEED A HEAD CLEANER FOR VIDEO MACHINE
I find the best way to clean a video head is to take the top cover off and go inside it. To clean get some Servisol Video 40 (you can buy this online or at Radio Shack (USA) or Maplin (UK). Spray this on every part the tape touches. Use a cotton bud to remove any bad dirt. Leave to dry. When you are ready use it, put an old tape to test it, but make certain it's not damaged or it will put more muck on it. If you see sparkles or the picture is still bad clean again the main video head. Keep doing this till it comes clean. If after 6 or more goes at it, if it still won't come clean, then assume the video head is faulty.
May 14, 2013 | Televison & Video
How can I keep my gravel clean?
The most effective way to keep your gravel clean is by using gravel cleaner. I suggest investing in a heavy duty syphon-powered cleaner and use it once a week to help keep your tank clean.
Aug 28, 2012 | Aquaculture Fish
Renault megane scenic coolant loss
A small leak in the head gasket will cause the coolant to disappear,but will not always be visible steam from the tailpipe.(small leak).A good way to check for this is to remove the spark plugs(keep them in order),and see if one of them is cleaner than the rest.(The coolant will steam clean the plug,and leave a slight greenish hue in some cases).If you do find this,you're looking at doing a head gasket.
Aug 08, 2012 | Renault Cars & Trucks
I have a brother DCP-770CW yellow is not printing how do i clean the head manually auto cleaner is not doing the job
Hi Good day!! Too bad i think the problem is the print head of your unit. maybe the tube inside that connects from the print head is clogged. i suggest to contact your local supplier to repair it or replace it if the unit is still in warranty process..
May 03, 2012 | Brother DCP Office Equipment & Supplies
Sound volume decreases to nearly inaudible,it appears to be related to batterys or spring holding batterys
head is dirty.use headcleaner liquid with clean cotton cloth, just rub the head with head cleaner . best of luck keep smiling..
Jan 15, 2011 | RCA RP3503
2003 f-150 skipping
Could be the IAC ( idle Air Controller ) is not opening far enough to keep the idle smooth when you put the truck in drive.
Under the plastic throttle body cover is the IAC bolted to the back of the throttle body. It is held on with 2 8mm ( 9 mm ? ) hex head bolts.
I used throttle body cleaner to clean mine when I had an idle problem.
The other thing could be the MAFS ( Mass AirFlow Sensor ) needs to be cleaned. Some throttle body cleaner is MAFS safe, it will specifically say on the can.
The MAFS is in the airfilter housing, it is a little stand tube with a wire in it. Only spray it clean, don't rub it.
While you are cleaning both, have the battery disconnected, to clean the leaned settings that the PCM has.
After you clean both and put everything back together, follow 2 drive cycles to complete all emissions tests, and start the relearn process ( quicker than letting the truck learn the new ones on the fly ).
Good drive cycle description is at this URL
http://www.obdii.com/drivecycleford.html
Feb 06, 2010 | 2003 Ford F150 Regular Cab
I just changed the batttery on my 2000 Montero Sport but now everytime I start my car it dies unles I keep my foot on the gas.What is wrong?
Maybe you should clean the throttle body with carb cleaner. Take off the air intake hose and spray the cleaner while the engine is idling. You will need to keep the truck running while doing so, this will clean the throttle plate and the idle air control valve.
Nov 09, 2009 | Mitsubishi Montero Sport Cars & Trucks
Rubber seal got dirty
Clean thoroughly with scouring pad and liquid cleaner, you will not get all the marks off,but as long as you get the worst off, it should be o/k.
To keep it from getting any worse, do a 90oC wash with powder in, but without clothes at least once a month, this will help keep it clean.
The problem is initially caused by doing too many low temp washes, so this is why you need to do a hot boil wash periodically.
Please rate my solution.
Thanks.
May 15, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Epson stylus cx3600
If you took out the sponge pad that runs left to right under the head and didn't put it back right the chances are the print head is catching on it and passing ink back and forth. Check the pas is sat correctly and clean under the print head with a light solvent cleaner like windowlene/windex liquid
Jul 25, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Photo R320 InkJet Printer Logo
627 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
