Question about Zoom X6 (5590) DSL Modem (55900003)
Reset button does not work zoom x6
Hello, I was updating the firmware of my zoom x6 when it sttoped, now I can not get into the administration page ( tried 10.0.0.2 several times) neither the reset button works, I have tried several times, help please.
    Genius:
  • 1,605 Answers
This a long one, I have to cut it into 2 parts. Since Fixya have limited space on each of the reponds.
There few steps that you need to take in order to get to the x6 modem.
You may already taken these steps before, but you need to re do this again:
Step1:
Disconnected the modem from the computer and turn it off.
Make sure the DSL software is installed on the computer.
Disconnect the ISP cable from the modem and leave it off for now.
Turn off the computer.
Step2:
Reset the DSL by insert a paper clip into the “reset” pinhole on the rear panel of the DSL and press 3 times (press down and hold for 2 sec).
Connect the DSL to the computer and turn of the DSL first then the computer.
Step3:
Open the browser and type in http://10.0.0.2 on the address bar, press enter.
If this do not open the DSL login page.
Do the following; close the browser.
Open the DOS prompt (if you have windows Xp or Vista-start>>all programs>>accessories>>command prompt.
Type in “ipconfig/all” (without he quote mark) at the blinking curser.
This is what you should see, with little variation, dependent on what is on the network.
Posted on Nov 28, 2008
  • Frank
    Frank Nov 28, 2008
    Note: the “x” in the file indicates the last 3 digit of the 12 digital number)
    “Microsoft Windows XP [version x.x.xxx]
    Copyright 1985-2001 Microsoft Corp.
    Windows IP Configuration
    Host Name……………………………...:your computer name
    Primary Dns Suffix…………………..:
    Node Type……………………………….:Hydrid
    IP Routing Enabled…………………..:No
    WINS Proxy Enabled………………..:No
    DNS Suffix Search List……………….: your ISP name
    Ethernet Adapter Network Connection 2:
    Connection-Specific DNS Suffix…………:your IPS name
    Description………………………………………..:
    Ni-PCI card
    Physical Address……………………………….:xx-xx-xx-xx-xx-xx (network card MAC address)
    DHCP Enabled……………………………………:Yes
    Autoconfiguration Enable………………….:Yes
    IP Address………………………………………….:10.0.0.x
    Subnet Mask……………………………………….:255.255.255.x
    Default Gateway…………………………………:10.0.0.x
    DHCP Server………………………………………..: 10.0.0.x
    DNS Server…………………………………………..:10.0.0.x
    Primary WINS server…………………………….:10.0.0.x
    Secondary WINS server………………………..:10.0.0.x
    Lease Obtained……………………………………..:Friday, November 28, 2008 9:00AM
    Lease Expires………………………………………….: Friday, November 28, 2008 9:00AM
    Step4:
    Open the Internet Browser and type in the DHCP address.
    You should be able to get access to the DSL.
    The default administrator log in is:
    Admin
    Zoomads1(it is a number one not a character at the end).
Zoom X6 router does not properly initiate...
The first thing i would do is try to get hold of another router to test on that line to make sure the problem is not with the telephone line or even connecting to the ISP, if you dont have a problem with the second router it is safe to assume the router is at fault, in this case i would reset to factory conditions and then try again, if the problem continued i would go to the zoom website and look for a firmware upgrade.
Jul 02, 2009 | Computers & Internet
Zoom x6 reset back button does not work
it will work, you have to hold the button in for around 60 secs
regards and please remember to rate us
Nov 27, 2008 | Zoom X6 (5590) DSL Modem (55900003)
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Modem Speed Dropped With Updated firmware
try to lower down the MTU settings of your router. If that does not work, you can try to isolate the concern by using another modem and checking if the same problem happens. if it does, then it is a problem with your ISP but if not then it is on the modem. You can try reset and reconfigure or firmware upgrade.
Apr 27, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Problem with password change
Check your manual if you have the option to change your password. Also try if there is a reset switch; dont do thiese unless you have properly noted down settings particular informations on ISP for your ruter to connect properly again.
Dec 23, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
How to make itouch work with the zoom x6
you have to go to bottom right click the thiung that looks like a computer the y be a button that says fix
Dec 10, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom x6 router
Well for most zoom X6 routers I saw it's
http://10.0.0.2
That should take you to the main page. The manual is located here for X6 models.
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
In the manual it's on page 13. I would download a copy of the manual and read it as well.
Nov 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 wireless router
Hi, With or without the firmware update, the wireless should work and be indicated with the WLAN led. Have you done an update? Have you tried a hard reset? Most routers would require a reset to default after a firmware update. Pls be reminded that when you do a hard reset, all configuration would be lost, better log them down or do a backup. Alternately, you can check your router's web based configuration manager, apparently, there is an enable/disable feature/selection for the WLAN. Verify that is set to enable. Hope this be of help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
Oct 02, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom X6 (5590) DSL Modem (55900003) Logo
238 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
